Intermittent Charging System Failure message with B1087 code
Dcadizel
Year and Model: xc70 3.2 2010
Post by Dcadizel »
I have the same issue on my xc70 2010. Lin bus shorted, circuit open etc, engine hessitates after warming up, misfire of 5th cylinder, door lock failure, ignition coil primary secondary circuit issues. I thing it is related to lin bus, maybe ECM failure? I did work on serpentine belt and since then been having issues with misfires, and messages as in the topic. Battery seems good and alternator too. Im clueless
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
For my 2010 S80 I would get
P1087 Not permanent (Resolved on its own)
P2568 Not permanent (Resolved on its own)
Then last year I replaced the Radiator with the Prem Air sensor.
This sensor is on the LIN bus I believe
And it has been a year and the code didn’t return.
I documented this on $10,000 S80 Challenge
Note I did try to replace the sensor first but I broke the Radiator.
As for the misfire I need more information. Have you changed your Thermostat? What Spark Plugs are you using? Have you swapped ignition coils? Did you inspect coil #5 to see if appears broken?
Thanks
Paul
5wt
Year and Model: 2010 XC70
Post by 5wt »
Yak, my2010 xc70 has identical symptoms as yours. Turn off engine and restart warning goes away. Have you made any progress with this problem?
Appreciate any info you have.
Yak
Has thanked: 1 time
Post by Yak »
I’ve been meaning to get to replacing the radiator sensor, but my wife has been living with the intermittent charging system error, so the new sensor is still sitting on my workbench . Today it also threw a P2568, which indicates the Environmental Air Catalyst sensor on the radiator.
I guess I’ll see if I can replace the sensor without breaking the radiator.
