2000 Volvo C70 HT 2.3 TDC
subzerocarfanatic
Year and Model: 2000 Volvo C70 HT
Has thanked: 75 times
Been thanked: 10 times
Post by subzerocarfanatic »
Thanks for your help.
subzerocarfanatic
lol...my 2 6 month old Akita pups love it too, they are seeing snow for the first time today.
Has thanked: 1611 times
Been thanked: 4072 times
Sorry if I sound harsh on type. My therapist says I should eat fewer harsh brownies.
You do have the Legend, Robert Spinner down in NM, btw. Check out his videos
subzerocarfanatic
i checked the injector plugs and the injectors them self, they all read around 12.3 - 12.5 Ohms and I am not getting 12 volts at the injector 2 wire plug, i tested the green wire on injector plug like suggested.
So we need to swim upstream and find where we lose the 12 Volts you know you have at the battery...
RHP posted this in another thread, here is the one to follow..
download/file.php?id=49276&mode=view
Follow that green wire from 24/43 [3] and keep going back until you find 12 Volts, then find what is stopping it from getting got the injectors and MAF.
Clarification
24/43 is the designation for a connector
24/43 [3] is the number 3 pin in the 24/43 connector
Im using the brackets [] to note the little box 3 on that diagram
subzerocarfanatic
ok, thanks, i will check this out and get back to you. I just got finished taking the entire blue ground wire from battery and the 3 or 4 junctions where is bolts to frame and car body for ground and cleaned all the connection up and soldered every connection so it's not just crimped at all ground spots, can't hurt, done the same with positive to fuse box, positive to starter and to alternator.
subzerocarfanatic
Wanted to thank you for your time and help! I wish i knew how to do the picture posting thing so i could post my progress, might help someone else oneday with related issues.
subzerocarfanatic wrote: 28 Oct 2019, 15:32 Wanted to thank you for your time and help! I wish i knew how to do the picture posting thing so i could post my progress, might help someone else oneday with related issues.
You have to be in full editior mode (button right below the text box on the default 'QUICK REPLY' mode, then use the 'Attachments' tab, add file, choose, and that will load pictures.
subzerocarfanatic
what does 23/11 represent in the wiring diagram?Is there something that identifies each area on this wiring diagram so i know what each one represents, for example ( 7/17 is the MAF sensor plug wiring harness,i would like to know what 23/11 and 24/43 is?
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
subzerocarfanatic wrote: 28 Oct 2019, 18:30 what does 23/11 represent in the wiring diagram?
The common Power junction for the MAF and the Fuel injectors. Look .. 23/11 is connected to fuse 11B/3.
23/X are junctions.
24/X are connectors.
11Y/X are fuses, where Y is the fuse panel and X is the fuse on that panel.
Active
Past
