I just ordered 10 o-rings from this Porsche and Alfa brake specialist:
https://www.pmbperformance.com/catalog/ ... 694936.htm
They are square cut EPDM o-rings. Many of the vintage Porsche and Alfa-Romeo cars came with smallish 2 piece Ate rear calipers which look very similar to the Ate rear calipers on Volvo 850's.
I have to admit that the pictures of restored Porsche calipers with original spec yellow zinc plating looked really sharp.
o-rings that seal caliper halves
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
850oldschool
Fitment confirmed! These are, in fact, the real deal. PMB appears to have a well deserved sterling reputation in the vintage Porsche community.
If you're not a putzy weirdo like me, you probably don't have to worry about these, just clean them up what you have and reinstall them. However, if you pick up a deal on a used caliper and what you receive are the two separate iron pieces in good condition in a box, minus all the rubber parts and other doodads, it could be pretty useful to know where to get these o-rings.
It should also be noted that the standard hardware store o-rings are usually made from buna-n, which is not recommended for exposure to brake fluid. So at least make sure whatever o-ring you install is EPDM.
I have to admit that this little adventure started me wondering if anybody has successfully used silicone bathtub caulk in place of these o-rings.
850oldschool
I looked at the Ate kit and several others which all lacked the two little o-rings, so I just bought the Ate one. I guess I should have looked a little harder!
- 29 Replies
- 2320 Views
Last post by Clemens
- 17 Replies
- 684 Views
Last post by jonesg
- 15 Replies
- 6462 Views
Last post by wizechatmgr
- 2083 Views
- 2800 Views
Last post by FireFox31
