Seriously
When I search for front engine mount I get 1500 pages of hits and lots of chaff
Part number nails it
Notes on P80 passenger side engine mount, 8631698
- Has thanked: 1611 times
- Been thanked: 4073 times
- Has thanked: 316 times
- Been thanked: 531 times
Yup, gotta be specific with the mounts. The front and rear "engine pads" are almost identical, but different. Then the passenger side one looks totally different.
This was the one from the '03 S60... it was trashed! I wish I took a picture of the one on the 98 V70 I just replaced the engine in. It was by far the worst I'd seen... totally separated into two pieces. I didn't even bother unbolting it to lift the engine, then realized the front part was hung up under the bottom bracket. Unbolted it and it let the engine loose.
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
Btw . From personal experience, I can confirm that some of these side engine mounts are chassis number dependent.
I have a 99 s70 and tried to use a used engine pad from a 98 s70 and it bolted to my frame just fine.
However, the mount to engine holes didn't line up.
All due to this being a chassis number dependent part.
I remember seeing a split on parts pages, I believe it was midway through 1998.
- June
- Has thanked: 523 times
- Been thanked: 261 times
I'm afraid it's worse than a VW!!!! He quit school, joined the Marines and bought a God awful brand new Honda Civic Sport in red... it has the stupidest looking exhaust pipe i have ever seen. The whole car is ugly, it makes me sick every time I see it. His parents drive Honda as well... I am beside myself...... a HONDA........abscate wrote: 18 Apr 2020, 10:18
Remember to tell Juniorette no dating guys with car covers, unless there is a Beetle underneath
Now they are trying to get married during this Coronavirus nightmare. Anyone who knows me, knows my biggest pet peeve is HONDA! It could also be said I hate them. I could accept Toyota or Subaru, but NEVER Honda! I am so disappointed.
I still have a son, at least I can hope for better from him. I'll warn him to lookout for beetles!
He has never driven, and as far as I know if it doesn't have a monitor or a keyboard, he isn't serious about it. So no wedding anytime soon.
I did my best to be as polite about Honds as possible. I didn't want to break MVS posting rules. My opinion could not be given in full color. Screwdrivers ventilating seats is small potatoes compared to Honda. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
June and Abscate, part numbers are good but readers should be aware that the side engine mount pad was redesigned somewhere around the 98 to 99 break. There are two different versions of this mount that look almost exactly the same, but the mounting holes WILL NOT line up if you have the wrong one for your car. I am guessing that you two are aware of this, but it needs to be pointed out to other readers and searchers. I just did mine on the '98 V70. At about 155k miles, the one that went bad was not a factory OEM Volvo part., so I may be on my third. I installed a Rein part. This was actually a pretty easy and quick job. I saw no signs of corrosion at all, but I don't live in upstate NY. In case anyone wants to know what the symptoms are, they are mostly noise and vibration. You may think you have an issue with your exhaust system. When the mount goes bad, the engine is free to move around because the rubber pad is no longer bonded to the brackets. It may not be obvious just by looking at it, but as soon as you lift the engine a bit with a floor jack, it is readily apparent.
All U.S. market models.
All running and on the road.
Eddystone, You nailed This.
I had an open issue with occasional clunking in the CVs and guess what! It all went away with the motor mount replacement.
This was ugly...
This was ugly...
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Not to abuse a somewhat dead horse here, the usaparts website lists no fewer than seven (7) part numbers, and on another page shows two more - 8631699 and 9480190 - that seem to be NLA. Even plunking my VIN into the search template doesn't lessen confusion.
https://usparts.volvocars.com/a/Volvo_1 ... 79397.html
It might help if we document the hole positions next time someone has one of these off
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Pretty sure my XC needs one, maybe this spring?
2023 Lexus RZ450e -66k
- 17 Replies
- 3770 Views
- 2017 Views
Last post by matthew1
- 1687 Views
Last post by alschnertz
- 12 Replies
- 3577 Views
- 1077 Views
Last post by Ozark Lee
