What's wrong with my 2001 S60 t5 - Anyone in zip 97206?
Volvogal98
Year and Model: 2001 s60 t5
Has thanked: 1 time
Post by Volvogal98 »
I also have the newer icarsoft vol 2 I got that instead of vida system maybe that was a mistake.....
Has thanked: 1610 times
Been thanked: 4068 times
Put up your zip in help wanted and see if someone is nearby with VIDA to help out
Volvo owners here are a pretty good bunch.
viewtopic.php?f=4&t=91744
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Fully charge your battery. Those codes may be caused by a weak battery. While it is charging double check all your work. When satisfied and batter is fully charged clear all codes. Have your son start the car and isolate where (and if) the noise is still present.
Did the V70 donor part number match the original part number? You can cross reference to see if they are swappable.
You can also do a deep dive into the original TB and look to see if the film contacts are all messed up. Don't butcher it as you may want to a SACR unit on it.
The high pitch whine followed by a click and then silence is the happy song of a compatible throttle body and software
Volvogal98
Has thanked: 1 time
update.....The car is working!! I have the famous abs/set light going but code says no voltage from pump so my next step is trouble shooting that one....but at least I can drive the car now.....and sell my 98 s90..
Thanks all for your help :)
Great! The abs controllers are expensive parts so used is the way to go on these.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I had a beautiful V70 2001 T5 wagon sorry to say but NO companies doing ABS module refurbishment for this year; not even XeModex. New ABS controllers about $1,000USD. Used controllers had the same codes for me and the 2 yaw sensors in the cabin for DSTC no longer in production. Try BBS remanufacturing as a longshot.
Once the heater core, head gasket and transmission S2 solenoid all failed within months of each other I called it quits. I still miss her jewel blue paintwork. Good that you got her running because not all ETMs are programmed to the same software version.
I now drive a Korean boat with diesel German running gear, darned reliable but no performance or character.
