Is the ABS module an easy cheapies fix? How do I test that?scot850 wrote: 02 Jul 2020, 06:12 Pull the plugs on #4 an #5 and check they are not wet. There is another thread running where the owner was having leaking injectors after a re-build.
The fact you have all these issues it could be one of 2 other things and or a bad battery:
1) Electrical portion of the ignition switch. It can cause all sort of mayhem. Did you try switching off and re-starting?
2) I had random lights coming on and weird running and it was the ABS module of all things.
The other thing could be a bad connector or air/vacuum leaks.
Not sure why the TPS is showing as a code.
98 s70 glt rough start [P0304 P0305 , swapped plug wires] Topic is solved
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- Has thanked: 311 times
- Been thanked: 817 times
Did you unhook the ABS module during the job? The connector is really finicky, make sure it is seated properly.
Or maybe the module has finally gone out. Matty Moo is still the way to go there https://www.midwest-abs.com/. There is some troubleshooting info on that page too.
- Has thanked: 2205 times
+ 1 with eriks suggestion. Junkyard ABS modules (check Mid-West ABS website for module compatibility. There are different versions. Price was around $100 with lifetime warranty.
- 1239 Views
Last post by blomkvist
- 1668 Views
Last post by RickHaleParker
- 2015 Views
Last post by jtp
- 27 Replies
- 4231 Views
Last post by dmechnic
- 1325 Views
Last post by Peteh1
