Front grille question
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
subzerocarfanatic wrote: 16 Jul 2020, 10:37 Yeah, I found an older 96 version with the black badge, I think I like the newer ones, they are expensive to replace though worth it I suppose.I found a new OEM grille,just the chrome part with no badges or anything for $39 but then I have to purchase the clips, post, and new Volvo badge which is around $55- $60 itself.
If you have your old one then you do not need to purchase any new clips (the black ones). What post are you talking about? Also, the 99 + had badge clips (the silver ones that secure the badge to the grille) that you could pry up and reuse if you flatten. 98's used a much more rigid one that is similar to a nut. The badge is the only thing you need but those should fit from either. Note, if you pull a badge from a 98 waterfall (chrome grille) then its two inner clip posts will not line up. The badge will still mount onto the grille via the outer posts, but the inner ones will not line up. I have not confirmed if this is the case for all waterfall grilles.
2008 S60 2.5T Auto (Sold)
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Roger that on the Blue.
I went with a newer egg-crate
and liked it so much, I went with
Blue wheel centers, too! Good Look... :)
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
1998-2002 should be waterfall grille like 1998-2000 "other" P80s, Eggcrate was a 2003-4 thing And XCs. Note the comments about the badge. Any 1998-2000 Base, GLT, AWD, or T5 will do, or 1998-2002 C70. All over the junkyards.
Find the weight, check shipping from 32547 and I'll give you one. I've got a spare.
Current Volvos:
FLXC90
Post by FLXC90 »
BEJinFbk wrote: 16 Jul 2020, 10:31 Keep in mind, the ‘98 had the older black “square” logo like 850’s.
‘99-‘00 got the newer blue badge that’s a slighty different shape.
96 is an 850 If it is it will not fit, one of the subtle changes made for the 70 series
Current Volvos:
subzerocarfanatic
Year and Model: 2000 Volvo C70 HT
Has thanked: 75 times
Been thanked: 10 times
Post by subzerocarfanatic »
FLXC90 wrote: 16 Jul 2020, 17:51
I meant to say 98 not 96.
Has thanked: 1609 times
Been thanked: 4065 times
Why did the chicken cross the road?
To avoid looking at the egg crate grill.....
Cluck cluck cluck.
Never mix Shell and Mobil gasoline.
subzerocarfanatic
abscate wrote: 18 Jul 2020, 04:27 Why did the chicken cross the road?
Cluck cluck cluck.
abscate...your quite a character. lol
