SAS Delete Troubleshooting (96 850)
- Has thanked: 1611 times
- Been thanked: 4075 times
The solenoid needs to be in place. If you remove the valve, you need to plug the hole in the exhaust manifold, thread size......standby
ToriWhite
- Year and Model: 1996 850
- Has thanked: 20 times
- Been thanked: 6 times
If I leave all the pump & tubing in place, do I need to plug the hole still? Or do I have to remove tubing and plug it for the SAS delete to work? I thought plugging it was just what people did when they removed the pump to declutter the bayabscate wrote: 11 Aug 2020, 19:07 The solenoid needs to be in place. If you remove the valve, you need to plug the hole in the exhaust manifold, thread size......standby
Richard99
- Year and Model: 2000 V70XC
- Has thanked: 26 times
- Been thanked: 23 times
I never really understood the desire to do the SAS delete. I know it can be a bit pricey to replace the components but it's an easy fix and then you won't have to worry about resale or emissions to another state.
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
2000 Volvo V70XC
- misha
- Has thanked: 155 times
- Been thanked: 432 times
If sas valve fails,the condensation(water)from exhaust valve will go through air pump and then be sucked into intake,passing by MAF sensor and damage it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
ToriWhite
Interesting findings today.. this may be the final piece of the puzzle. Today; after many power cycles and codes cleared, I realized something..
...the 0410 CEL code is coming on before I start the engine! Even with everything plugged in! The only things that run pre-start (that I know of) is a little squirt from the fuel pump, and that’s it- no engine, no vacuum pressure to check lines, and that the SAS only does its SASsy business after ignition... makes me think this actually is a soldering fault!
(Unless I’m mistaken about the timing of events here.. does the SAS only kick off after ignition, or is it before, like the Fuel pump?)
Pending this being a soldering fault or not, I also read that I should ‘have the white lines from the vacuum tree removed and capped’ in another thread - I don’t understand the vacuum tree, and am still coming to grips with how the SAS system works, so I’d appreciate if someone told me that the pic I attached of plugging one white line (the one to the relay, the other white line goes to the air box, so I assume it stays(?)) that this won’t explode my engine by firing it up with the line off (I may seem neurotic here, but due to unforeseen circumstances, this hobby car is now suddenly my only car, and I’ll be in a real pinch if I cook my MAF or something!)
My Volvo has 0 resale value, while it’s perfectly functional and a great car with arguably another decade left in it; the market doesn’t look fondly at a rusted out 20+ year old car with mismatched body panelsRichard99 wrote: 12 Aug 2020, 00:13 I never really understood the desire to do the SAS delete. I know it can be a bit pricey to replace the components but it's an easy fix and then you won't have to worry about resale or emissions to another state.
That code is probably sticky in the ECU from previous faults or there is an electrical fault it is detecting.
SaS pumps air into the exhaust manifold during warmup , then shuts off until the next cold start cycle
ToriWhite
Tried sitting the car with battery DC for a couple minutes, code still came back on ignition pos 1, no engine activity. Starting to really think it’s just a soldering fault, but I also don’t want to get my hopes up.abscate wrote: 13 Aug 2020, 07:32 That code is probably sticky in the ECU from previous faults or there is an electrical fault it is detecting.
Going to pull out the ECU and peek around, I know the resistor should have a ‘drop’ of 1.6, (which I’ll have to look up how to test with a volt-meter), I assume too that I’ve got to clip it out just to test it, right?
You can Leave it in, and measure voltage to ground on each side with the key on. Be careful with your probes, practice with key off and battery disconnected until you know you won’t touch anything else
It’s a diode, not a resistor.
- 884 Views
Last post by misha
- 25 Replies
- 5938 Views
Last post by Gerd
- 872 Views
Last post by wapitiscat
- 4465 Views
- 1154 Views
