Just hone the Dickens out of it?abscate wrote: 18 Sep 2020, 11:54 I don’t have time to sit next to my manifold all night reading “Great Expectations”
NA intake runners vs turbo
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Current Volvos:
Nice!
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I'm a woodworker so I'll make a quick jig to hold the manifold on my bench and a template that I can bolt to the manifold flange. Then use a pattern bit in a router and make repeated passes to cut it away. I make round windows and jambs so this is not out of line. Should leave a perfect edge. Yes - doing this with a grinder etc would take forever and would probably be way less than true.
But a compass and a router...
1999 V70 GLT
1999 V70 GLT
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
While the intake is off peen several places around the cup plug with the vac nipple on it. Those have lots of history of popping out if you run boost up higher than stock.
- Has thanked: 2856 times
- Been thanked: 1332 times
I'm always humbled by work like this. Can you snap photos as you go along?Sveedy wrote: 18 Sep 2020, 17:53 I'm a woodworker so I'll make a quick jig to hold the manifold on my bench and a template that I can bolt to the manifold flange. Then use a pattern bit in a router and make repeated passes to cut it away. I make round windows and jambs so this is not out of line. Should leave a perfect edge. Yes - doing this with a grinder etc would take forever and would probably be way less than true.
But a compass and a router...![]()
So bad it's good
- Sveedy
So bad it's good :lol
[/quote]
X2
And yes - I'll document everything for the next person who wants to go this route.
Thanks Jimmy - I'll address that potential problem.
[/quote]
X2
1999 V70 GLT
1999 V70 GLT
- Sveedy
Question - I have been collecting the parts for this mod, but does anyone know if, or how, this will change my fuel millage ?
1999 V70 GLT
1999 V70 GLT
- FLXC90
That would be entirely up to your right foot. It will allow for better airflow, but it's still limited by throttle opening.
Current Volvos:
- 2032 Views
Last post by sergitin32
- 524 Views
Last post by erikv11
- 7350 Views
Last post by rspi
- 17 Replies
- 6042 Views
Last post by biohazrd76
- 743 Views
Last post by Vazfx16
