I wanted to get the thoughts of some of you on this swap on the turbo models, check out my channel if youre into performance upgrades and diy stuff. Comments are welcome and appreciated. Thanks if you visit.
NA intake manifold swap on turbo 850R
biohazrd76
- Year and Model: 1997 850R
1997 850 R, black.
Ipd HD tcv, msd coil pack, ipd HD cbv, ipd stage 1 ecu flash, iridium plugs,heavy gauge plug wires, airbox cover delete, k&N cone filter directly before maf, ipd HD end links.
Graveyard: 1993 850 glt, NA 168 bhp,gold. Hit and run 2009 totaled
1995 850 Turbo, 222 bhp totaled
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Your intake manifold isn't holding your back, considering one of the hole of the stock intercooler is 2 inch.
Upgrade to do88 intercooler first.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
biohazrd76
Does it mount in stock location?
1997 850 R, black.
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
I put the n/a intake on my 98 S70 T5 M and initially, I saw an increase in torque, but after about 2 days it settled back down and was really no improvement at all. I must say though, since installing the n/a intake my highway easily exceeds 32MPG with the cruise set at 70. I also have an upgraded intercooler. Again, didn't really feel a difference, but my objective there was to reduce intake temps and thus improve the longevity of the engine. If my logic is flawed I would like to know. Lastly, if you go with an aftermarket intercooler, be careful when you park. The intercooler sits about 2 inches below the radiator and if you hit the parking block you will rip your radiator apart. Don't ask me how I know!!!!!
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Whenever installing an larger intake, you should also make sure you have a good flowing exhaust.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Why would it settle down? Is this motronic 4.3 getting used to the new part trying to cut back on power?
1996 855 R,
2010 V70 D5,
2010 V70 D5,
shaker_chi
I don't know the science behind the "settling down", but initially I did see quite a difference in torque. To get that back you would have to disconnect the battery every couple of days which would be a pain. Perhaps the ecu "learns" the new airflow and adjusts itself. Sorry, can't answer that one, but I know I'm not the only one to experience this.
FWIK and researched, this is the only way to regain the baseline parameters and temporarily erase the adaptively learned parameters.shaker_chi wrote:I don't know the science behind the "settling down", but initially I did see quite a difference in torque. To get that back you would have to disconnect the battery every couple of days which would be a pain. Perhaps the ecu "learns" the new airflow and adjusts itself. Sorry, can't answer that one, but I know I'm not the only one to experience this.
Sucks.
ugh smh 850 Turbo fridge
biohazrd76
Just an update. NA intake and throttle body swap has a good 500 miles on it, just got ipd rip kit and adapters. Also added white injectors. This has given it so much more punch (torque) at 2500-3000rpm. Traction becomes an issue on launch...No driveability issues or cel. I ported and polished the intake to match the gaskets and ipd phenolic spacer. This isolates the intake from the head for cooler temps. Getting things together now to connect an OBX downpipe from ebay for 150$ . Vehicle has to pass emissions and inspection.
1997 850 R, black.
shaker_chi
I had no problem passing emissions with my N/A intake. What injectors originally came with your 850R? I thought the whites were stock. Did you get a tune from ARD or IPD yet? Have you noticed an improvement in gas mileage?
- 1157 Views
Last post by precopster
- 2273 Views
Last post by Bloitz
- 1299 Views
Last post by 98v70xc206
- 807 Views
Last post by Sommerfeldt
- 2696 Views
