04 V70 2.5T MAF reads way high, no codes, stalls out Topic is solved
ZachS
It's certainly some sort of leak. Went for a drive with MAF unplugged. Past 2500RPM it sounds like a racecar, but has no boost. Gonna have to check the intercooler and anywhere else for obvious leaks.
- Been thanked: 4068 times
jimmy57 wrote: 01 Oct 2020, 09:04 If you ruptured a hose anywhere between turbo outlet around back to throttle you'd have your symptoms. Intercoolers can split at core to end tank seam also so that needs to be checked. The turbo can pump air out of the leak as it is driven enough by exhaust the moment you start engine to force the air out. You do not have to open throttle to get turbo sped up enough for this to occur on low pressure turbo engines. The MAF is registering that air. If no leaks then failed MAF sensor is possible.
Whose got the Volvo Horns? Looks like they need to go back to Texas , again.
Thanks, Jimmy!
This failure brought me to MVS 7 years ago!
- 706 Views
Last post by xlr8r3
- 15 Replies
- 3436 Views
- 33 Replies
- 1983 Views
Last post by misha
- 815 Views
Last post by APCalifornia
- 3289 Views
Last post by jimmy57
