Alternator Pulley Fell Off Topic is solved
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Re Alternator...
Do not buy local bc it is all Chinese junk.
Buy Bosch (New). Check FCPEuro etc.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
ljsommar1 wrote: 29 Oct 2020, 09:00 The pulley on my alternator came off while I was about 90 miles from home. Almost unbelievably I was able to make it home. The serpentine belt still drove the alternator shaft. I did not even discharge the battery.
I ordered a new (not rebuilt) and have not had a problem since, about 30K miles. I rebuilt the original to have as a spare. It is worth noting most alternators sold are rebuilt units and most do not replace the bearings and if they do, they use cheap Chinese ones.
I was 90 miles from home myself. Having Gold AAA I got it towed home for free.
After I throw on the new Bosch alternator I'm rebuilding my OE also. What else should I replace along with the pulley and voltage regulator?
XC70Rider
Post by XC70Rider »
xHeart wrote: 29 Oct 2020, 10:58
XC70Rider wrote: 27 Oct 2020, 15:08 On the way to work the alternator pulley fell off
Why would a pulley fell off?
Rick explained it earlier:
When the belt slows down, the inertia of the Alternator Rotor produces a relative CW spin between the shaft and pulley.
Indicates the pulley is not “free-wheel” or “overrunning” like it should.
I got cut off driving 55mph.
The tensioner is OE so I'm replacing it also.
XC70Rider
Post by XC70Rider »
Drove 500+ miles since throwing pulley back on with no issues. Still installing a new Bosch alternator this weekend.
Post by cn90 »
Can someone post a DIY alternator replacement for 2.5T engine?
I wrote a DIY for 1998 S70 GLT a few yrs ago...
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
cn90 wrote: 30 Oct 2020, 14:07 Can someone post a DIY alternator replacement for 2.5T engine?
The DIY for 2001 V70XC takes pulling out the cooling fan only -- two 10mm screws. Unbolt the alternator and carry it along the alley to the air box end, and pull up and maneuver it out. Way easy!
I can share the details if set up works for you?
XC70Rider
Post by XC70Rider »
Similar task to removing the entire thermostat housing. Need to remove belt, PS pump out of way, intercooler pipe, drain coolant, and remove upper radiator hose. I'll also remove the fan to make it easier.
Wondering if the lower bolt on the belt tensioner can be accessed from above or does right front wheel liner need removal?
Post by cn90 »
Oh,
Found the DIY S60 Alternator by FCPEuro:
Has thanked: 1610 times
Been thanked: 4065 times
Don’t forget to cover up the induction pipes when you remove the induction hoses. Dropping stuff in there is a bad day
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
XC70Rider asked above: "What else should I replace along with the pulley and voltage regulator?"
An alternator's bearings are always replaced in a rebuild. I doubt Volvo sourced "lifetime bearings".
