abscate wrote: 06 Nov 2020, 05:32Don’t use stop leak. There are small orfices in this engine that don’t respond well to glueMikeM1212 wrote: 05 Nov 2020, 17:28abscate wrote: 05 Nov 2020, 15:47 Fix that pinhole with someJB weld. You need pressure in your cooling system to stop the coolant from boiling
You can then also monitor,the coolant level correctly and see if you are losing coolant somewhere
Gonna have to pull raidator to fix pinhole , was thinking of trying the radiator stop-leak solution and pouring it in to see if it might stop it. It worked for 2 years on an old car and never leaked a drop after. The previous owner took care of car very well and said before pinhole leak in radiator the coolant level never dropped between coolant changes. Sucks cause I just can't figure it out. The water in and coming out of the tailpipe if confusing me.
Can you get to the pinhole without pulling the radiator? If it’s spraying on the radiator it should’ve visible. I drove a jb welded radiator for 100 k miles/ 4 years
I don't think I can without pulling it because it is right where there plastic meets the metal , worst case I will swap out with brand new radiator. The stuff in and coming out of tailpipe is whats confusing /worrying me. Out here again today looking at it and once again it's literally straight water coming out exhaust.
