12V source for testing Haldex pump 30783079 Topic is solved
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Has thanked: 292 times
Been thanked: 765 times
Re: 12V source for testing Haldex pump
Post by erikv11 »
Zero life in the pump once I got it off the car, same as the test when it was on.
I have a new one coming though I was chicken to go with Dorman, shelled out for the Volvo one. I'll probably put a Dorman on our S60, it needs one too. But that's for like spring time - one prop shaft per quarter please!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 113 times
Been thanked: 262 times
Post by Blacklab467 »
You can't go wrong with the Volvo pump, I'll probably find myself wishing I had done the same at some point but so far so good. You may elect to try and clean and rebuild your old one, mine was mostly full of brush dust and oily goo, I thought I could clean up the armature and put some new brushes and bearings in it and keep it for a spare but then broke a plastic piece that I think holds the brushes so I threw it out. I suspect that the only cause of failure of it was being dirty and gummed up.
2003 XC 70 (sold)
Blacklab467
I was hoping to get at least a couple years out of the Dorman but it died this weekend! 6 months old. New Volvo one is on order and another filter and bottle of fluid.
2003 XC 70 (sold)
Has thanked: 1500 times
Been thanked: 3810 times
Blacklab467 wrote: 03 Jan 2021, 13:59 I was hoping to get at least a couple years out of the Dorman but it died this weekend! 6 months old. New Volvo one is on order and another filter and bottle of fluid.
Thanks for the follow up, you just saved someone a lot Of hassle here.
Can you guys post the Volvo part number for this to make it searchable, please?
On edit, found it
https://www.fcpeuro.com/products/volvo- ... wE#fitment
Post by erikv11 »
Volvo AOC Haldex Oil Pump Kit - Genuine Volvo 30783079
This kit includes pump, installation screws, and the large nut for the oscillation damper.
Order Volvo-branded Haldex oil and the filter separately.
Or this kit has all three: https://www.fcpeuro.com/products/volvo- ... ervicekit1
'06 S60 R, 197k
