Bought ODB scanner.
Car started very rough.
Codes:
P0113#12
intake air
Temperature sensor 1
Circuit High Bank 1
P0103#12
Mass or Volume Air Flow Sensor A Circuit High
Live Data
MAF (g/s) 103.85
2003 v70 stalls very often. Parts replaced. Need advise
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
That maf value is through the roof, assuming it was measured on idle?? The more info you provide the greater the chance is you'll solve this.
BMW 540i 2002
S70 Base 2000
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
No! Go to fcp euro, pick an OEM replacement and buy that (on Amazon, or wherever you like). Volvo ECMs are very picky when it comes to MAF. Bosch ME7 only works with Bosch MAF, one part number fitted to that particular ECU.antoniveb wrote: 16 Apr 2021, 16:17 It runs with MAF unplugged
Buying this
https://www.autozone.com/engine-managem ... 826_0_4995
antoniveb
- Year and Model: 2003 V70
Yes. on idlekallekula wrote: 16 Apr 2021, 17:11 That maf value is through the roof, assuming it was measured on idle?? The more info you provide the greater the chance is you'll solve this.
antoniveb
OMG it's $200+vtl wrote: 16 Apr 2021, 17:12No! Go to fcp euro, pick an OEM replacement and buy that (on Amazon, or wherever you like). Volvo ECMs are very picky when it comes to MAF. Bosch ME7 only works with Bosch MAF, one part number fitted to that particular ECU.antoniveb wrote: 16 Apr 2021, 16:17 It runs with MAF unplugged
Buying this
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
antoniveb wrote: 16 Apr 2021, 17:33OMG it's $200+vtl wrote: 16 Apr 2021, 17:12No! Go to fcp euro, pick an OEM replacement and buy that (on Amazon, or wherever you like). Volvo ECMs are very picky when it comes to MAF. Bosch ME7 only works with Bosch MAF, one part number fitted to that particular ECU.antoniveb wrote: 16 Apr 2021, 16:17 It runs with MAF unplugged
Buying this
or $10 at the junkyard.
- Has thanked: 1611 times
- Been thanked: 4075 times
You can fix your car for $200, or $10 plus junkyard trip....
Or just light $87 on fire and still have a broken car.
