It's not always the ABS module
Has thanked: 1610 times
Been thanked: 4068 times
Clemens wrote: 17 Jun 2021, 14:28
abscate wrote: 17 Jun 2021, 03:29 I have a business partner in Voralberg, and it used to crack him up at trade shows when I told people we were in Austria, land of kangaroos. Geography isn’t always a strong point in the US
Decades ago, I pulled up in a Burger King Drive through in Valley Springs, CA 95252, and the girl at the window asks me where I'm from. Said she could hear an accent, said I wasn't from the Valley (true). I replied "Austria". She said: Wow, I always wanted to go there. Is Crocodile Dundee like a national hero for you? I told her we have a monument for him in like every town. Then I took off with my 72 Continental...
You invented hot dogs, too.
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
now the secret's out ...
1996 855 R,
2010 V70 D5,
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Decades ago, I drove up with my girlfriend to Valley Springs, CA 95252 for a weekend. She's my wife now. Still. We were driving a 69 Mustang ...
Clemens
Post by Clemens »
erikv11 wrote: 23 Jul 2021, 15:59
Erik, what got you to go to Valley Springs? The golf course, the lake or crack? No too much else to do there ...
1996 855 R,
2010 V70 D5,
Post by erikv11 »
We did go to the lake but really none of the above and nothing special really. It was the 80s, we had access to a house up there, just someplace to go and get out of the bay area.
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
I battle this on a daily basis.
There are years of threads across all forums that pretty much spell out that if the lights are on then the module is bad. Those days are done.
I scan every module that comes back in after I clean, repair and test it. Sometimes they have the standard 13 codes where they let the module go forever until the speedo was gone. Sometimes there's only two right rear codes where they decided to replace it the day the lights came on intermittently.
If the modules that didn't go all the way with 13 codes, 30% of those will show faults that aren't the module. It's almost always a wire. Usually up front.
"I checked the wires, they look great". Nope. They break internally from 20+ years of moving. That wire isn't as big as it looks, the wires inside are super thin. And you can't just plug a new section in on a 96-98
To make matters worse, people will get a scan and get told to buy new sensors from some mechanic. So they buy some aftermarket sensors and throw them in. So now they have a broken wire with some new sensors that are usually faulty out of the box. They put a new issue on top of the old one. This has happened on my end at least twenty times.
High/low voltage is another.
98 clusters failing
The ebd pressure switch does actually fail occasionally.
Tone rings rot apart, mainly up here where there is salt.
Cars that have been touched by drunken uncles or sketchy nephews that took an auto class in high school.
My personal favorite. "I just picked up this sweet Volvo for $500, the seller said all it needs is an abs module". When I hear that I know the car is a $2k FCP order away from being just OK. It's also loaded with butt connectors, zip ties, rtv all over and a mirror full of air fresheners to cover the smell of 500 cartons of cigarettes.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
:D :D :D
I got my butt kicked in a BMW E83 this Spring
With a new job in NYC SWMBO favourite non-Volvo car had a nice habit of kicking into limp mode 20 minutes after getting to highway speed. Nasty
I chased ignition and fuel and finally found a rusty tone ring on right rear , which was shutting off the ECU. Not a single code was set. Finally tracked it down with real time wheel speed data , seeing noise on the signal on that wheel.
Clemens
Post by Clemens »
Matty Moo wrote: 13 Aug 2021, 06:20 I battle this on a daily basis.
98 clusters failing
Well, with your rebuilt module on the way, at least I know that it can't be the module because you tested it.
My sensors read the right ohm values. Still lots of things to go bad.
1996 855 R,
2010 V70 D5,
Clemens
Post by Clemens »
@ Matty Moo:
You say you can't just replace broken wires on the 96 up cars. What is the solution then?
1996 855 R,
2010 V70 D5,
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Clemens wrote: 14 Aug 2021, 13:48 @ Matty Moo:
Abs sensor wiring can be repaired.
I repaired a section on my driver's side front abs sensor this winter.
The trick is to crimp the section with crimp connectors and not to solder....just like o2 sensor wiring.
In fact....replacement wiring for abs sensor from Volvo come as a pigtail wiring.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
