Even though we 96 upwards p80 owners know that the ABS/Tracs double orange means the module is faulty - it's not always the case, as I will photoproof here.
Interestingly, the lights were off in dry wearher and only came on in rauny condiruons, which made me suspect the wiring.
I guess a tiny rock got stuck in the ABS ring and slowly did grind off part of the sensor.
It's not always the ABS module
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
But, the fantastic thing is: even though this should have been the issue, the double orange is back. I will measure the ohms between the pins of each single wheel sensor at the main connector one of these days
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I had abs sensor wiring problem this winter on driver's side front wheel.
It drove me nuts and the symptoms are almost just like bad solders in abs/tracs module except that it always triggered abs/tracs light on full right turn(it took a while before i discovered that).
Turn the car off(wheels are straightened),re-start...abs/tracs off as soon as i take off and i could drive whole day on freeway or anywhere before i make a full right lock(while parking or getting into a garage) and the lights come on again.
The wiring cracked inside the silicone insulation...no visible cracks on the outside and it looked like new on inspection.
Vol-Fcr was showing a code for intermittent fault and open or short circuit on left front wheel sensor(driver's side).
Sensor checked out ok...then i used a multimeter on module's connector for coresponding sensor and wiggled a wiring while watching values.
As soon as i wiggled a wiring where rubber grommet fits in a slot on a strut imitating a wheel turn...multimeter read open circuit and when i release the wiring to return to it's normal position...proper resistance showed again on multimeter.
Again...no visible damage on the outer silicone insulation and i decided to cut open that area carefully.
As soon as i removed outer insulation...one of the wires was broken.
24 years of moving the wheels from left to the right full lock broke one of the wires.
I repaired that section by crimping a little male and female crimp connectors on both ends on the section,insulated it with a heat shrink tube and insulating tape and few months later it's ok and abs/tracs module is happy.
If my repaired section fails....i will probably splice in the whole cable in the inner fender area.
As far as i could saw...it isn't a regular wire...it looks more like an o2 sensor wire and it seems like it is resistance sensitive.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
Thanks Misha, that is what I am suspecting, because sometimes it seems to be triggered by full lock steering qheel action, sometimes not. Really weird
1996 855 R,
2010 V70 D5,
2010 V70 D5,
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 84 times
Had to replace the rear abs wiring and sensor as well some years ago. (s70)
It helps If the car has obd2, with a reader you can check for wheel signals... at least I was able to do this.
Agree that blindly replacing or fixing abs module is not the way to go.
850 T5-R '95 auto
- Clemens
Well, good to know about the wore replacement. Since you are so close by maybe we should finally meet, it's been in the back of my head for a long time.hausmeister wrote: 13 Jun 2021, 11:14 Had to replace the rear abs wiring and sensor as well some years ago. (s70)
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Been thanked: 4068 times
You guys should get together for a kangaroo BBQ.
I’ve never had any luck soldering those thin ABS wires in a way that lasted. In my maintenance record you will see I must have soldered them 4-5x. I finally realized the hours wasted were not worth the $50:cost of a new one
hausmeister
I'm down with that. But don't expect much, my 850 has been through a lot and looks like it. Which is good as I don't need to worry about anything being pretty any moreClemens wrote: 13 Jun 2021, 12:48 Since you are so close by maybe we should finally meet, it's been in the back of my head for a long time.
Love those Kangaroo burgers
850 T5-R '95 auto
I have a business partner in Voralberg, and it used to crack him up at trade shows when I told people we were in Austria, land of kangaroos. Geography isn’t always a strong point in the US
- Clemens
Decades ago, I pulled up in a Burger King Drive through in Valley Springs, CA 95252, and the girl at the window asks me where I'm from. Said she could hear an accent, said I wasn't from the Valley (true). I replied "Austria". She said: Wow, I always wanted to go there. Is Crocodile Dundee like a national hero for you? I told her we have a monument for him in like every town. Then I took off with my 72 Continental...abscate wrote: 17 Jun 2021, 03:29 I have a business partner in Voralberg, and it used to crack him up at trade shows when I told people we were in Austria, land of kangaroos. Geography isn’t always a strong point in the US
1996 855 R,
2010 V70 D5,
2010 V70 D5,
