Nope. Not done for. You’ve been cranking it with a no start and putting raw fuel into the cylinders which has lowered the compression. The ultimate manifestation of this is called “ lawn mower syndrome”
Try some starter fluid into the manifold ( brake booster vacuum fitting is a good place for a 3 second burst, 3.14 seconds in Canada) to see if it breathes fire
S70 rough running then stall [Sensor electrical plug corrosion] Topic is solved
- Been thanked: 4064 times
- patcal
- Has thanked: 99 times
- Been thanked: 10 times
I tried this the other day with no luck. I will try again since I had the plugs out. Thanks.abscate wrote: 26 Nov 2021, 11:24 Nope. Not done for. You’ve been cranking it with a no start and putting raw fuel into the cylinders which has lowered the compression. The ultimate manifestation of this is called “ lawn mower syndrome”
Pat Callaghan Jr.
98 S70 GLT
98 S70 GLT
- patcal
Well the starting fluid did nothing. Didn't even sputter. I pulled the cap & rotor. It's worn but I don't think it would keep it from starting. What do you think.
Pat Callaghan Jr.
98 S70 GLT
98 S70 GLT
It needs to be scruplously clean f oil and moisture. Scrape all the metal to shiny brass, clean out the oil with brake cleaner , then get it dry as a desert.
- patcal
I remember filing the rotor smooth & the cap contacts in my old air-cooled VW's. Helped them last a little longer. Of course back then caps & rotors weren't over $100. I will give that a try. Thanks.abscate wrote: 26 Nov 2021, 13:42 It needs to be scruplously clean f oil and moisture. Scrape all the metal to shiny brass, clean out the oil with brake cleaner , then get it dry as a desert.
Pat Callaghan Jr.
98 S70 GLT
98 S70 GLT
- Has thanked: 2197 times
- Been thanked: 1850 times
Your distributor cap looks either damp or oiled on the inside. Check for oil leaking into the distributor body from the cam seal.
Have you checked the pcv system recently with the glove test? It may be your system is blowing oil into the distributor and then the oil will absorb moisture in cold conditions after the engine has run.
- patcal
I did check the pcv system a couple of months ago. Nice strong vacuum. I'll clean the cap & rotor & try again. Thanks.scot850 wrote: 26 Nov 2021, 15:23 Your distributor cap looks either damp or oiled on the inside. Check for oil leaking into the distributor body from the cam seal.
Pat Callaghan Jr.
98 S70 GLT
98 S70 GLT
- Has thanked: 311 times
- Been thanked: 817 times
To elaborate on Neil's point: with the rotor off, pull the dust cap and the little metal disc it mounts to can then be removed via a single bolt with a 10 mm socket. Check the cam seal in there, is it seated properly?patcal wrote: 26 Nov 2021, 15:30I did check the pcv system a couple of months ago. Nice strong vacuum. I'll clean the cap & rotor & try again. Thanks.scot850 wrote: 26 Nov 2021, 15:23 Your distributor cap looks either damp or oiled on the inside. Check for oil leaking into the distributor body from the cam seal.
- RobTheModd
- Year and Model: 98 S70T5M
- Has thanked: 5 times
- Been thanked: 7 times
Hey bud, curious why you think its anything other than vac related?
I just had a similar issue with my 98, was just a popped off vac tube infront of the throttle body area.
Wish you were local, would just come over and give you a hand.
Have you fixed your Vac Tree? (Since you broke it, this is what I would start with now)
If the car is starting, but stumbling, your fuel/spark/etc is fine.
Answer me these if you can,
1. The S70 is Turbo correct?
2. Will it start and run?
3. Have you checked ALL of your Vac lines?
Like actually checked, Couplers as well (if turbo). Trace them from the Vac tree and manifold all the way to the other end.
4. Are there any Codes being thrown?
5. What caused you to jump straight to fuel issues?
- patcal
Thanks for the response. I actually got the car started & home yesterday. I had fuel to the injectors & spark at the plugs but no start. I went in to finally check the cam & crank sensor & the connectors were filled with green, fluffy corrosion. I cleaned it out & tested the sensor (they were fine) & it started. I have a new vacuum tree & several feet of hose to replace any that need it.
Pat Callaghan Jr.
98 S70 GLT
98 S70 GLT
- 14 Replies
- 1784 Views
Last post by EngineeringBloke
- 11 Replies
- 5890 Views
Last post by oragex
- 1910 Views
Last post by volvolugnut
- 22 Replies
- 1617 Views
- 2880 Views
Last post by ZionXIX
