Head warp tolerance.
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
I got the tools today, and If I place the straightedge on top of the head, the largest feeler I can fit is a 0.008 inch or 0.20 mm. It will only fit in the middle (of the long side), and there is resistance when I put the feeler gauge in. Do I have to resurface it?
Since my 2002 gasket is not MLS, can I use MLS? Would one gasket require resurfacing while the other doesn't?
2002 v70 X/C 288k miles
You are right on my personal tolerance for flatness. Anything over 0.006 inch I have it flattened.
I can see skipping it if your plan for the car is a few years of life and gentle use. It is a lot of sunk Labour cost to lose over a small cost of skimming.
At 250k miles your head should be in the shop for valves , anyway.
- 02V70
I resurfaced the head using a DIY method. Now, there is .003 of an inch in the middle near the coolant holes, and .005 of an inch at the very end. Is this good?
- 1415 Views
Last post by Ozark Lee
- 783 Views
- 13 Replies
- 8384 Views
Last post by lifeofgold
- 16 Replies
- 1866 Views
Last post by erikv11
- 1556 Views
Last post by jblackburn
