- Rover wasteland.JPG (81.98 KiB) Viewed 1093 times
The Resurrection/Insurrection of GrunHilde - 1998 V70 NA M56 421 Green
Dropped the heater core for replacement. Was original Volvo / Behr from late 1997
Firmed up, not final torque to front end bolts
Installed snow tires, and dropped her back onto her feet, and took her for a test drive!
All well.
All well.
- Has thanked: 2199 times
That is awesome news after all the work you have done on GrunHilde. Hopefully she will respond with a lot of good service for whoever the lucky person is who gets her.
Have you any more things you still have to do to complete this project?
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
Maybe "final torque" those front end bolts?
Left front abs sensor wires
Final torque front end
Final torque 36mm castle nuts
E brake
Rear tires
Heater core install
Reinstall alternator
Interior cleaning
E brake
Rear tires
Heater core install
Interior cleaning
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
You're a darn machine with the speed you're working on that =)
Got an eBay alternator and dropped it in. New serp belt,viciously tight. It ran very well with no tensioner. Could not install belt with tensioner , even after running for ten minutes.
Struggled to put tensioner back on with belt on, finally did using bottom bolt first on tensioner trick
Wisechatmgr figured this all out, he was on A game yesterday
Fuel leak stopped
Found a 2015 heater core in parts, will use that
Lost heater core bolt, torxt25 m5 x 15 mm. 986200
Have spare
Periodically stopped in for moral support painting living room
Fuel leak stopped
Have spare
- wizechatmgr
We had a room at the plaza that was painted Xerox red... It had to be repainted because apparently somehow subconsciously it causes people to fight.
It became an ugly green instead.
That belt was tighter than any belt I've dealt with before. I don't think the tensioner even did a full 1mm of movement when I removed the pin. I swear they made it a half inch or so short. At least it sparkles =P
ANd we are done under the hood!!!
Got a 2016 Heater core from stash - replaced, removed 5/8 bypass - silcone grease on o-rings, leak tested with water, then hooked up coolant.
No leaks - great heat in car.
Miles 184006
Radio code 5415
Miles 184006
Radio code 5415
- 1125 Views
Last post by FLXC90
- 303 Replies
- 37348 Views
Last post by bmdubya1198
- 15 Replies
- 2663 Views
Last post by Arathi
- 2852 Views
Last post by Brick850
- 890 Views
Last post by 93Regina
