crasbe
Year and Model: 02 S60, 98 V70 (EV)
Has thanked: 33 times
Been thanked: 82 times
Post by crasbe »
The dashboard kickpanel of my 1998 Volvo V70 I has a broken tab where it should be held in place by a screw under the steering wheel.
While the previous owner "fixed" that by screwing a drywall screw into the side of the kickpanel, I preferred a more lasting repair...
With Fusion 360 I created a 3D model which replicates the missing piece of the kickpanel and has a brim which will ensure a strong glue connection to the panel. In the profile of the model you can see that it follows the slight curvature of the panel as well, ensuring a good fit.
Screenshot 2024-03-26 012611.png (213.21 KiB) Viewed 2968 times
Screenshot 2024-03-26 012624.png (27.19 KiB) Viewed 2968 times
Due to the curvature it had to be 3D printed in a somewhat odd orientation, but it worked. This prototype is PLA, but the final version will probably be printed from ABS or PETG. PLA will start to become soft at around 60°C, which a black car (as mine is...) can reach on a very hot and sunny summer day.
As you can see, it fits very nicely on the kick panel and I'm sure it'll be a very strong repair.
Of course, something like that is not designed first try, so this is the evolution of this repair part.
Leftmost is the little piece that was furtunately remaining on my kick panel, so I could get some reference dimensions from it. The first version was too small because I mixed up the inner and outer dimensions. The second version fit quite well, but didn't have the curvature yet, so the contact area was not good yet. The third version is a cutaway to see if the model curvature fits the actual panel. The last part is the final prototype :)
The next repair will be on the dashboard, because the attachments for the kickpanel are broken on both sides...
Is that a common problem with Volvo V70s that this tab of the kickpanel breaks?
Or were the previous owners of my car just hacks who ripped the panel out instead of taking it out carefully?
If it's a common issue, I can publish the model files for the repair part.
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables :D
Has thanked: 2215 times
Been thanked: 1853 times
Simple answer is yes it is a common issue along with several other plastic parts like the corners of the glove box.
I just did a similar repair using bits and bobs I had kicking around. Small strips of metal behind those 2 outer tabs for one. The advantage I had was that the whole dash was out anyway to repair the normally broken lower dash section firewall mounts. I used JB Weld black plastic for the repairs and it has worked well.
Your solution though is truly magnificent and many thanks for doing this and sharing! I could see others looking for this part and whatever solution you come up with for the 2 tabs.
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
MoVolvos wrote: 25 Mar 2024, 15:21
Could be fuel, spark or timing. You want to be sure not to crank too many times in case you are flooding the cylinder and then the CAT. Turn the key to Position 2 and push the Schrader valve to see if there is fuel squirting out.
Next check the cap & rotor. If it seems to look okay then remove the 2 screws to expose the injectors. Unplug the connectors and with the key in the Position 2 test to see if you have Voltage at the leads. Polarity doesn't matter when checking. If you have voltage then check spark to the plugs.
Timing would be the last to check.
bmdubya1198 wrote: 25 Mar 2024, 14:50 Are you getting fuel? Almost sounds like a washed down cylinder.
Thank you, both! I don’t have a fuel pressure gauge (added to my list) but has fuel coming from the Schrader valve both times I checked. I unplugged the MAF sensor and then noticed that the small linkage arm with ball ends that comes off the throttle wheel was loose. (Why would this detach?) I disconnected and reconnected the spark plug wires, noticing that one seemed loose.
After about 20 seconds of cranking, it sputtered and finally started, with the tailpipe sending out a huge cloud of exhaust. Warming it to normal operating temperature, I turned it off, and it started a second time with no problem.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
brunocerous
crasbe wrote: 25 Mar 2024, 18:40 Is that a common problem with Volvo V70s that this tab of the kickpanel breaks?
This is amazing! Every one of my P80 vehicles had this issue. I’d love a copy of the file, if it’s not too much trouble.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
crasbe wrote: 25 Mar 2024, 18:40 The dashboard kickpanel of my 1998 Volvo V70 I has a broken tab where it should be held in place by a screw under the steering wheel.
I'd also love this file! This is a super common problem, I've tried to fix mine many times in many ways, but this is the best looking and appears to be the most effective.
I've glued a washer there previously, but that hasn't held up very well.
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Nicely done!
crasbe
Post by crasbe »
Thanks for the feedback and the kind words. Since this seems to be a bigger issue, I'll start a new thread in the evening and will publish the files on Printables.
Has thanked: 1613 times
Been thanked: 4077 times
Bdub for the win.
Youve won lifetime of Taylor Swift downloads for your Miata!!
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
brunocerous wrote: 25 Mar 2024, 19:56
Great you got it going! Do you think it was the one loose spark plug wire as the linkage arm still provided throttle input?
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
xanthefin wrote: 24 Mar 2024, 09:27 After first test I think i need adjust Speed conversion slightly.
I belief this is from VSS sensor? I need pull ABS fuse and go verify.
It was VSS so if ABS is bad can monitor VSS via automatic gearbox as alternative speedo.
Then made today short video Key programming on P80 platform (+ C70 and 40 series up to 2004?).
