Vida CEM swapping
RickHaleParker
Been thanked: 958 times
Re: Vida CEM swapping
Post by RickHaleParker »
vtl wrote: 03 Aug 2021, 22:24 That's a good data point, Rick, thanks!
CEM-L #1 Does crack @ 600 MHz, Samples = 100. Does crack @180MHz, Samples = 2
Code: Select all
180MHz,  Samples = 2
Candidate PIN 55 28 90 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 645 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..done
found PIN: 50 28 37 55 52 90
PIN is cracked in 378.78 seconds
Validating PIN
PIN verified.
done
CEM-L #2 Does not crack @ 600 MHz, Samples = 100. Does crack @180MHz, Samples = 2
Code: Select all
180MHz,  Samples = 2
Candidate PIN 55 20 00 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 645 seconds
Progress: 0%..5%..10%..15%..20%..done
found PIN: 85 20 47 55 20 00
PIN is cracked in 172.70 seconds
Validating PIN
PIN verified.
done
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
I wonder if pin order is different for this part number.
bosse
Year and Model: V50 -11
Post by bosse »
8690720 p1 cem is possible.
RickHaleParker
vtl wrote: 04 Aug 2021, 09:34 I wonder if pin order is different for this part number.
He knows the PIN on the 08690720. Cracker is not getting any of them correct. But this is the only one he has tried on the bench. We don't know that the bench setup is correct.
AA2020 wrote: 03 Aug 2021, 03:07 08690720 (2005): Correct PIN : 15 82 06 59 81 62
Candidate PIN 53 27 33 -- -- -- :
AA2020 could you test your bench setup with a already cracked CEM?
AA2020
Year and Model: 2007/ V50
Post by AA2020 »
RickHaleParker wrote: 04 Aug 2021, 10:48
Yes, 31254903 cracked on bench (and on car too) without any problem, every time.
08690720 Not cracked on bench, not cracked on car.
I/O Terminal connecting OK with Pin - 158206598162
Vida connected Ok on bench.
RickHaleParker
AA2020 wrote: 04 Aug 2021, 12:37 I/O Terminal connecting OK with Pin - 158206598162
And not a single one make the best candidates by latency or std .... Odd!
What you think VTL ... real fast chips? Are his latency times typical of a P1 CEM or on the fast side?
What hardware interfaces work with which I/O Terminal software ? I have two J2534 interfaces. KKL, ELM327. USB to TTL ... almost forgot Odin. :wink:
bosse
Post by bosse »
Ioterminal have it's own hardware.
Not possible to use other tools.
vtl
Post by vtl »
RickHaleParker wrote: 04 Aug 2021, 13:14 What you think VTL ... real fast chips? Are his latency times typical of a P1 CEM or on the fast side?
P1 is ancient Motorola running at turtle's speed, two of them. Could be something simple, like one MCU sits on CAN-HS, other one CAN-LS, and CAN-LS one is handling the pin routine check, while CAN-HS peer only forwards a request and reply. The cracker may be working there if the pin interrogation is done on CAN-LS. I think someone here had mentioned that, that his cracker started to work with his P1 CEM once he had hw/sw fixed to work on CAN-LS. Or maybe in email thread, I forgot.
RickHaleParker
bosse wrote: 04 Aug 2021, 14:58 Ioterminal have it's own hardware.
A direct answer .... cool!
alevol
Year and Model: 2005 S60
Has thanked: 6 times
Been thanked: 3 times
Post by alevol »
Hi. Got CEM-L 2007 with serial 700xxx. Tried samples from 40 to 100, tried LAT only and LAT+STD modes. No luck to crack it. Today will try to downclock the Teensy to 180MHz. I got the CEM on bench, so i can read the software with programmer.
Is there a way to disassemble the file or send it to somebody to disassemble it and check the PIN byte order?
Thanks
