Has thanked: 1850 times
Been thanked: 1712 times
Whilst in North America we did not get chipped anti-theft keys until 99 MY, in Europe I think they got them as far back as 96. Does your car have chipped keys?
When you say your car does not start with the key, do you mean you put the key in the ignition and nothing happens at all, or does the car turn over and not start?
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
It was a no crank issue. Turns out to be the PNP switch harness. I'll update my post.
Regarding whether the key has a chip or not, I'll need to know as I plan to have another set made. Bonus if the fob can be fixed/duplicated too as it has broken traces. This is part of a bigger key related issue in that the key only works on the driver's side. Passenger side does not move, tailgate moves but does not lock/unlock
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
I had fun trying to turn two tired axleshafts into a decent one
Inner joint came out in 15min on first one, gave up after over an hour on the second axle (pictured here :lol: )
Took a few measurements while I was at it, a manual axle thread might be in order
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
Goupil wrote: 13 May 2024, 15:06 I had fun trying to turn two tired axleshafts into a decent one
I know the feeling. Are you trying to alter a different axle? Or just piece together bits from the correct axles for your car?
xanthefin
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
RedBrickCollector wrote: 12 May 2024, 10:56 It was a no crank issue. Turns out to be the PNP switch harness. I'll update my post.
Term fob is for remote control. But key chip can be cloned on 850 IMMO2 systems.. i can do it manually bit by bit as i know algorythm. IMMO3.. not so open.
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
I finally had my buddy over to replace my front cam seals which were stuck in there pretty good. I used this fantastic cam gear tool I built with great success. And yes, abscate, that is nautic blue ... :D
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Clemens wrote: 14 May 2024, 13:57 I finally had my buddy over to replace my front cam seals which were stuck in there pretty good. I used this fantastic cam gear tool I built with great success. And yes, abscate, that is nautic blue ... :D 20240514_210611.jpg
That tool looks very surprised :D
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
^^^ It does!
Say, is that a custom MDF cam tool?
(medium density fiberboard)
Clemens
Post by Clemens »
nope, it's 10mm birch plywood.
Summer: 1996 855 R
Donor: 1995 854 10V
Goupil
Post by Goupil »
ZionXIX wrote: 13 May 2024, 16:00
Axle on the car had a bad inner, with an okay boot, and a good outer with a torn boot.
Spare axle (same P/N) had a good inner with a bad boot and both good boot and outer joint :)
For some reason the seal lip on the inner joint is different by 4mm, I wonder if one came off a car and the other was a later build part.
Managed to get all the good stuff into one axle that should last a few months, I've got Subaru parts to buy right now :lol:
