Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
For what it's worth, I have tried three different types of glue on the dash mounts - a two part "plastic" epoxy, ABS glue, and original J.B. Weld.
Only one that didn't fail was J.B. Weld.
1999 V70 GLT
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
abscate wrote: 02 Jun 2024, 05:23
foggydogg wrote: 02 Jun 2024, 00:01
abscate wrote: 01 Jun 2024, 04:22
Bung 3517907 still available new!!
3517907 comes up as a 740 bracket
Let’s try 3517097 instead, thanks for the covering fire….
Brings to mind the old saw about the dyslexic agnostic insomniac who laid awake all night wondering if there really was a Dog.
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
jsrnsis wrote: 31 May 2024, 20:56
yanga001 wrote: 29 May 2024, 22:49 Not a volvo week for me. After vacation we had a busy schedule. My partners 08 Acura RDX decided to spring a pretty sizeable coolant leak from around the turbo area. She took it to a mechanic as i was busy and they said 4k for a new turbo. Car runs great, air fuel ratios are nominal, boost is built, and no white smoke is laid down on acceleration.
Funnily enough it uses a TD04H turbo with coolant and oil cooling. Did a late night diag yesterday and answered 50% of my questions. There was a leak on a water cooled exhaust manifold but it does not seem to be active. I need to get my inspection camera to the backside of the turbo where the coolant pips connect to it to see if that area is leaking. If its not then i get to deal with rusty bolts.
Got my winters changed to summers and found a half inch rock in one of the winters. That explains why it emptied in two days.
Frustrating week as my 08 S60 AC weakened a bit and my filler head for the charging cans also broke.
If i can hold off deaths embrace on my partners car then i can save a good chunk of money which is not too available. Looks like ill trade bloody knuckles and bruised hands for that wish.
Hoping sunshine is around the corner.
Water cooled exhaust manifold? Like a boat?
Yup, like a boat.
Turns out the leak is from the coolant loop of the TD04 Turbo. Somehow it seems there is a hairline crack in it.
I am going to try some headgasket sealer given that a turbo replacement is expensive on a good day, and very expensive in her car. We need the car for another year or two so that should buy us the time. My theory is that the sealer will make its way to the turbo and react with the heat of the turbo in order to seal the hairline crack. The crack appears to be closer to the exhaust side so that may work to our advantage.
In any case, i need to flush her coolant with a chemical cleaner beforehand to ensure no bad reactions. Then refill with distilled water, run with pour-n-go by blue devil and check for seal. If it works then ill replace it with honda coolant and cross my fingers we get another few years out of it.
The little problems that come often dominate so much time!
2008 S60 2.5T Auto (Sold)
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
RedBrickCollector wrote: 02 Jun 2024, 09:04
jsrnsis wrote: 01 Jun 2024, 21:06 I had a replacement I was lining the inside of the dashboard with fibreglass sheets soaked in ABS cement until I got distracted with other projects, might be something to think about if you do find a replacement, at least to reinforce the 4 tabs and other mounting points.
Tried something similar. Might be the fault of my cement but they came undone pretty quickly, back to the drawing board for me
I was finding that some of the pieces would pull right off, I found that trying to do larger pieces would end up with the cement starting to set before I could go back over the back of the fiberglass with more cement, maybe causing a weaker bond. At the very least, the mounting tabs seem be strengthened, and I'll feel better about putting it in a car rather than if I just touched up some of the cracks.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
Car sat for a week and now won't start. Seems to be a progression of before. Car cranks, "catches" but immediately dies. Leaning towards fuel pump relay or the pump itself. Anyone have any other things I should check?
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
If in doubt about fuel supply, do a fuel pressure test at the fuel rail. The pressure can tell you health of the pump and relay. Low pressure likely the pump and no pressure likely the relay.
RedBrickCollector
Still waiting on a gauge. I can hear the pump prime but I'm not sure it stays on when I crank. Is it possible for the relay to fail in this way?
'97 950 T-5 Wagon
foggydogg
Post by foggydogg »
RedBrickCollector wrote: 05 Jun 2024, 09:57 Still waiting on a gauge. I can hear the pump prime but I'm not sure it stays on when I crank. Is it possible for the relay to fail in this way?
Yes. Make the jumper wire to replace the relay as a trouble-shooting step. If no change then head for the pump, test as noted.
Has thanked: 1850 times
Been thanked: 1712 times
Started on prepping the R for summer use at last. Only got as far as getting 2 of the summer rims and tires fitted. Then got side tracked with info sourcing on jobs for others on Volvos.
The XC60 replacement trans is on the way now with an ETA sometime before the end of time (maybe). Assuming the Canadian border guards don't go on strike tomorrow.
Then texting with my buddies son about the spare radiator I found for his leaking version on his 06 S60 2.5T AWD. He got back to me to say it looks like it has somehow managed to fix itself and stopped leaking for the last year or so since we replaced his failed engine mounts?! He wants to drop by on the weekend to get help for some other issues on his car.
Next I did as Abscate recommended and went to find an alternator/starter rebuilder with any skills. Found one about 10 minutes from where I live. Love these small one man businesses in a small unit packed with stuff and an helpful owner. I had taken a failed Bosch rebuilt alternator to see if it was repairable as I had no idea why it had failed as I had not removed it. It belongs to another student I help with his 06 V50 T5 AWD. It managed to have a battery fail, then this alternator and then the replacement 'Amazon special' also failed all withing 4 weeks. I wrote about that saga on the V50/P1 forum section. I want to know why it had failed so I could be more sure it was not going to be an ongoing issue. I explained the issue to him. He does not work on Volvo stuff, but immediately recognized the alternator as not a Bosch but a Denso unit that Bosch has remanufactured. He mentioned that alternator has a known weakness which is not common with Denso products. He checked it and it was fine. In fact there was nothing obvious other than badly worn brushes, worn shiny slip rings and a failing bearing. He is going to open it up and give it a good clean and do one more check. The bonus is he is a long time Denso service shop. He also mentioned that rebuilders use lower quality parts like bearings and brushes that are so soft they wear out quickly. He will only replace with OE quality parts. I guess we will see how this works out in time. He quoted $175 CDN (about $125-130 US) to rebuild in worst case but if there is nothing else found it may be less. I can live with that.
Maybe tomorrow afternoon I can get the other 2 wheels on the R and then check levels and see if it will start. The 'boss' want 'her' car back for the summer (could have sworn it was mine, or at least 'ours', but clearly it is not!!).
Has thanked: 1505 times
Been thanked: 3818 times
These guys and gals are out there, they seldom are on the Internet. I just drove by the guy who used to do all of our VW Beetle generators in the 1960s , in Niagara Falls. His grandson does it now!
