Has thanked: 1847 times
Been thanked: 1710 times
I can't recall if they used 14" or 15" tires. If you are tall (over 6') if the car has a sunroof you may find you have little headroom. I'm a little over 6' 1" and I found by head brushing the sunroof. I had a 760 turbo and also a 940 turbo wagon. I liked both of the cars. They felt solid. I would prefer a manual in the winter. We are not even allowed studded tires here in Calgary. Our son had an accident when his car slid on a slope into another car even on snow and ice tires that were almost new.
Plenty of weight in the trunk is the secret in winters. The RWD autos, don't have the winter start mode like the P80 autos.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
454cid wrote: 21 Aug 2024, 09:35
The 850 is due for an oil change. I kinda would like to try the Valvoline Restore and Protect that's really supposed to clean up an engine, but it's a little light... only 5w30, which Volvo seems to think is basically water.
The 5 part indicates turning resistance at a specific (low) temperature, see the SAE website for that info, or if you're brave enough, www.bobistheoilguy.com. The 30 part is the pouring viscosity, and works fine in our cars. 0w8 is an artifact of US fuel economy standards, used on some brand new cars designed to run on such flimsy juice.
There is an automotive lubricant petrochemical engineer posting on Y/T as https://www.youtube.com/@themotoroilgeek
who does a pretty good job of showing lab results for these things (he is the guy who designed the Joe Gibbs line of lubricants marketed as Driven), and he owns an oil testing lab. He covered that Valvoline product not long ago.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
454cid wrote: 21 Aug 2024, 22:07
volvolugnut wrote: 21 Aug 2024, 12:30 Rear wheel drive 240/740 Volvos (especially wagons) are great in snow. Weight balance is good. Ground clearance good. Power is not at all excessive. With rear chains they may be unstoppable until you are pushing snow.
We don't get enough snow here to warrant chains. I think they might actually be illegal. It's good to know my idea of a 740 isn't totally crazy, Though. Last time I looked at it, I forgot to see what size tires it needs.
There is usually little snow here also, BUT there have been foot deep snow storms here in the last 40 years. Southern Oklahoma. I think I only put chains on my '75 245 once.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
foggydogg wrote: 22 Aug 2024, 09:02
Yes, but for some reason, Volvo ranks 5w30 as having a much lower upper temperature limit than 10w30. It makes no sense to me, who understands what you just wrote above. I'd have to look again, in the manual, but I think Volvo says 5w30 tops out at something ridiculous like 70F, but 10w30 tops out at the same temperature as 5w40.
That's Lake Speed Jr. I've watched several of his videos, including at least one on Restore & Protect. Really good info.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
454cid
Post by 454cid »
scot850 wrote: 22 Aug 2024, 08:41 I can't recall if they used 14" or 15" tires. If you are tall (over 6') if the car has a sunroof you may find you have little headroom. I'm a little over 6' 1" and I found by head brushing the sunroof. I had a 760 turbo and also a 940 turbo wagon. I liked both of the cars. They felt solid. I would prefer a manual in the winter.
I'm not that tall, so I should be fine there. I think it does have a sunroof, which is something mu 850 lacks. My S70 had one, and I miss it.... have to drive the Mercedes to get that now.
That surprises me. I figured studs would be fairly normal in Canada. We can technically have them here in MI, but practically can't. They're legal if approved by the manufacturer, and the automakers don't... or don't care. The law might not even specify if it's the automaker or tiremaker. This is just what I've heard/read, so maybe not completely accurate.
I use winter mode more often, for stop and go construction traffic. If I don't, I get a harsh shift right before I have to apply the brakes again... most annoying.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Studs are ok outside the city. I the city we used to get lots of chinook warm winds in winter which could leave the roads bare a lot of the time. Studded tires wreck the asphalt when the roads are bare. So the city banned them. Not we are getting more snow, they have decided instead of allowing studded tires, they will spray liquid death on the roads (de-icer) which is speculated to be why the main water main burst at half expected lifespan (great plan, run all major pipes under roadways). That stuff is highly corrosive.
I asked the roads department if thay had checked the corrosive properties of the de-icer. The answer was no!! Then the guy says, it affects the bridge decks as it eats through the re-bar!!
BlackBart
Been thanked: 884 times
Post by BlackBart »
Rusting rebar is a serious issue.
Y’know, Maine also has a main water main.
Has thanked: 1504 times
Been thanked: 3817 times
I love watching the heads spin as my studded snows clack clack clack up the road, only to see a little silver S70 making all the noise..
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
Need some help since my current car isn't a good reference. Should this corner of the dash be lined up flush with the A-pillar trim?
Also, reference pictures for the dashpad "clip" next to the A/C vent would be much appreciated, it's totally missing from both sides on mine
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
I don't have an 850 for comparison to help. If this link works does this help with the positioning you are trying to figure outs?
https://www.seymourpope.com/vehicle-det ... gallery-23
Neil
