Has thanked: 1848 times
Been thanked: 1710 times
Where you live that is a wise idea! Still loving that color!
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
Did another drain and fill on the transmission last night before driving out to CT to pick up a bunch of spare parts. Transmission still gets a bit clunky when at low speeds getting back on the gas after a bit of coasting. Very noticeable in Connecticut traffic.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
I can't recall now what all you have done on this car. Usual check is the engine mounts (specifically the crank pully/RH mount, and top and bottom torque mounts), and then also the CV joints. At least that would reduce the likely chance of it not being the trans. Also worth checking the sub-frame mounts too.
Hopefully something in there and not the trans. How many dump and fills have you done on the trans?
jsrnsis
Post by jsrnsis »
scot850 wrote: 31 Oct 2024, 12:21 I can't recall now what all you have done on this car. Usual check is the engine mounts (specifically the crank pully/RH mount, and top and bottom torque mounts), and then also the CV joints. At least that would reduce the likely chance of it not being the trans. Also worth checking the sub-frame mounts too.
I did 3 with Liqui Moly ATF1100 which is Dex 3G/H (actually says Dex 2/3 on the bottle woops) and then two with the ATF1200 Dex 3H within a few hundred miles of each other.
The ATF1200 is a darker color red and more viscous, at least at room temperature.
First drain and fill I did was around when I got the car, and then the second around 5000 miles later. ATF was already dark by then, with a little sludge on the drain plug. Third drain and fill was around 2000 miles after that, again dark fluid and some sludge on the drain plug.
When I drained the fourth time after switching to the 1200, fluid was still red, but it was only around 200-300 miles of use.
First drain and fill only 3 liters came out so I put 3 liters in. Since then I've been putting in as close to 3.5 liters as I can, and 3.5 liters comes out when I drain. I'll have to check the motor mounts again. I just replaced the top torque mount and firewall torque mount, both were torn. I might need to buy a FWD transmission lower torque mount and graft the larger bushing together with the special AWD smaller bushing.
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
Careful with the lower torque mount offsets from AWD and FWD are different. IPD do an (expensive) AWD replacement for the small end with a poly-bush.
The fluid sounds like it is where it needs to be.
jsrnsis
Post by jsrnsis »
I had posted about my original 188k mile fuel filter, then forgot I said I would post pictures.
Filter disassembly
Filter disassembly
Filter media
Filter media
Filter media unrolled
As you can see, the media was a little dirty. Almost 2x the recommended change interval.
Filter reassembly
Filter reassembly
Got a little distracted and pulled out the flux core welder to make this elegant wine glass (pen/sharpie holder)
Cross country
Cross country
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
Has thanked: 1505 times
Been thanked: 3818 times
Awesome wine glass holder.
I’ve got FWD parts pulled off Shagg. How far off I87 are you and which exit?
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
My 850 back on road after 5? months sitting finally. Got today Finnish MOT pass.
Had to replace rear brake calibers as at MOT other side jammed and made very nice whining noise while driving back. Father was helping there as had cut the brake lines too to get old ones off.
Sure on other side i made that "knob" or whatever in line and almost finished when noticed i left the nut off. Its so easy mistake.
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
The groaning started on Friday night, and I added ATF to the reservoir, but it just kept disappearing. Today, I got under and saw a pretty healthy PS fluid leak from the steering rack.
1998 Volvo V70 steering rack leak
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
brunocerous wrote: 04 Nov 2024, 11:39 The groaning started on Friday night, and I added ATF to the reservoir, but it just kept disappearing. Today, I got under and saw a pretty healthy PS fluid leak from the steering rack.
I had an 850 like that, I tried switching to Valvoline MaxLIfe ATF stop leak and it fixed it. Worth a try if you don't want to go down the rabbit hole of rack work on an 850. The remans are crap, everything likely badly rusted, etc.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
