1999 2000 MY - The "Bastards" Draft Info Thread
Has thanked: 1610 times
Been thanked: 4065 times
Airbag change from -98 to 99
jimmy57 wrote: ↑23 Mar 2024, 18:29
The change from DC current wiring to AC makes the harness change. The end plugs on 99 will have capacitors and 98 will not. The bags and belts don't care but if you have the harness from 99 and airbag control unit original to the car that is a problem as the capacitors in end plugs for airbag will make a DC current control unit think there is an open circuit.
Door handle change late 1998
viewtopic.php?t=96027
Radiator overflow hose routing change ftom 1998 to 1999
viewtopic.php?t=78410&start=10830
1999 2000
-1998
-1998
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
So I found a set of front seats from a '98. I know that the air bag system changed, so what parts are interchangeable with a '99 ?
Can the basic parts just be switched, or is it only the skins ?
1999 V70 GLT
Link to discussion of AWD PROPELLOR SHAFTS for these years, vin breaks
viewtopic.php?p=395698#p395698
From the source
“No. 1999 is the CAN intro year and TCU also gets security matching starting that year. No plug n play. 97 850 LPT and 98 LPT have interchangeable TCUs but 97 HPT are M4.3 with 98 HPT becoming M4.4. I remember a pin differs between those two and the 98 HPT will have a transmission error with 97 and down HPT TCU in it.”
Link to pictures of different variants of the 1999 and 2000 outer timing belt cover
viewtopic.php?t=107268
