- DennisCA
- Year and Model: 1996 850
- Has thanked: 6 times
- Been thanked: 71 times
Tried to remove the outer CV joint (broken gaiter). I got the axle out easily enough but the damn retainer ring seems to have broken inside the groove and there's no way to expand it. I am now not sure what to do. Force it off with violence?
- Has thanked: 317 times
- Been thanked: 531 times
Yup, that's about the only option. Lots of hammering!DennisCA wrote: 17 Apr 2025, 11:30 Tried to remove the outer CV joint (broken gaiter). I got the axle out easily enough but the damn retainer ring seems to have broken inside the groove and there's no way to expand it. I am now not sure what to do. Force it off with violence?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
I think you're going to need an aftermarket head unit (radio) and camera...Marzzy wrote: 17 Apr 2025, 08:39 Want to fix driver sill emblem. R design. Want to add backup camera. All those years without a backup camera and now I want one. Does anyone know anything about adding thise to a r design?? Note: this car had a small accident right rear corner years ago. And I found some disconnected wire harness where the rear speaker is in the trunk. Any thoughts? I'm not sure where it goes on the rear door . Maybe the license plate light assy? There's 2. Thanks for any help also Revis the cat loves the pics!!
2023 Lexus RZ450e -66k
- wizechatmgr
When you go to put it back in, place some decent CV or axle grease all around the ring so it pops in and out easier next time. We had a bugger of a time getting one of mine in until I lubed the shaft.DennisCA wrote: 17 Apr 2025, 11:30 Tried to remove the outer CV joint (broken gaiter). I got the axle out easily enough but the damn retainer ring seems to have broken inside the groove and there's no way to expand it. I am now not sure what to do. Force it off with violence?
- wizechatmgr
I don't get that many visitors to the office unless we've fricked up in epic fashion. This typically means my unit is on the news. Thankfully that has not happened during my tenure. I think $8B+ without mistake thus far. Zero % acceptable oops factor.abscate wrote: 16 Apr 2025, 03:20Ugh. Still want to know the difference between AWD and XC stays. My life won’t be complete not knowing this.wizechatmgr wrote: 15 Apr 2025, 17:05 Went to replace panhard/stay on rear of '99 XC today. Found additional damage such as a sway bar mount being destroyed. Hit everything with Fluidfilm for now, will be back under there when I return to US.
How did that eccentric bolt look? Definitely heat the nut and turn carefully to avoid breaking, they are NLA but we have spares in stock, thanks to Neil.
My cat turned 126 years old today…my office now has 6 regulator visitors , black, black white feet. And grey not shown
Marzzy
- Year and Model: 2015 xc60 R design
Thank uvm. I wasn't sure if I needed the radio head unit. It looks like the wiring is there. This car was hit in the left rear a few years back. No airbags went off but I think they replaced the electronic lift gate with a standard one. For 55k miles somethings look like they have been worked on underneath the car and not well. Exhaust hanger ect... today xc60 I will try to make a mode of operation list to change the oil. I get the weirdest noise when I give it power l. It feels up front. Like something with the AWD. I'll look further when it's on lift. Oh...also abs module missing. Wonder if this is normal?
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Awww...abscate wrote: 16 Apr 2025, 03:20 My cat turned 126 years old today…my office now has 6 regulator visitors , black, black white feet. And grey not shown
My office window just popped open and it's adventure land!
- Has thanked: 2215 times
- Been thanked: 1853 times
Marzzy, while you are in the wrong forum for your question, I'm not sure on the head units for Volvo's of that age. I'm going to assume that the head unit currently fitted may not have an input to support the bac up camera.
When I wanted a back up camera, my local electronics store were able to fit a Sony head unit to my 03 Toyota 4Runner. I wired and drilled the hole for the camera wire feed into the tailgate and they did the rest for me.
If you decide to try this yourself, be aware the wi-fi back up cameras can be time delayed. I have know owners to back into objects thet were close up due to the delay.
Good Luck! Maybe try posting in the correct forum area for your vehicle as it is more likely you will find support for your questions there:
viewforum.php?f=26
viewforum.php?f=26
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Yes sir. Which is good because no Canbus troubles
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
