Has thanked: 1614 times
Been thanked: 4078 times
DennisCA wrote: 01 Sep 2025, 04:11 Fenders are back on the car. Put some wax based rust proofing on the rear before I put them back. I have wet sanded and polished the fenders to reduce some of the orange peel. I effed up majorly when polishing on the lower edge of the repair and the clear coat let go.
I managed to save it by repainting that area with my Iwata air brush and the fade out spray I bought really works well when you need to blend over spray. I can see it's not perfect because I was loosing patience and sanity at the time. But I think most people will not notice.
I think the color matches pretty well. Once I get the rest of the car washed and polished I think it'll all blend together well.
We aren’t “ most. People “ here.
Ye will be judged.
:lol:
( It looks great !)
Has thanked: 2215 times
Been thanked: 1853 times
Agreed, if I only had half your talent with body/paint work!
DennisCA
Year and Model: 1996 850
Has thanked: 6 times
Been thanked: 71 times
Post by DennisCA »
Thanks! I don't feel like I got talent though, so many small missteps and near disasters and scrambling to fix them. It's more a matter of just keeping at it I think.
I did another thing to the car which might be one of the oddest mods people have seen. I've put a 2nd washer pump in series with the original one. Just how many people want extra power for the washers?
Pump is powered directly to the battery (fused!) via a relay that uses a vampire connection to the OEM pump.
Also V70 wiper arms:
454cid
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
DennisCA wrote: 03 Sep 2025, 01:37 Just how many people want extra power for the washers?
Me! My 850 does not have great washers like my S70 did, and it's not just the nozzles. One of these days I need to go through the system, and see if I can find anything wrong with it. I already disconnected the headlight wipers so I'm not losing washer fluid there anymore. I never thought of a second pump, so thank you for that idea. Maybe I'll do something similar if I can't fix mine otherwise.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
5underpressure
Year and Model: 1998 v70
Has thanked: 11 times
Been thanked: 13 times
Post by 5underpressure »
Went car camping last week, busted the passenger side radiator tank.
Two weeks out for a mahle radiator, is the nissens terrible?
98 v70 t5 m
I have used Nissens and no issues.
While I have been waiting for parts for the P2 XC70 main service to arrive, I decided to check out the SC-901 head unit I pulled from the junkyard recently before the window to return to PnP closed. Fortunately after some cleaning and technical issues with my test system for some reason, it fired up and after a clean of the laser eye, the 3CD cassette now loads and unloads as it should and the cassette as well. The bonus is all the lights seem to still be good! I noticed some of the buttons were still a little grubby, so after the photo I went back and cleaned them again. They look better now!
SC-901 head unit
SC-901 head unit
I also pulled the Dolby processor as well, but some numpty had pulled the cable which is NLA as well as the speaker. The cable is NLA so I will have to try to make up one from parts I have so I can test it and another I have also from a C70 P80. I have a dash top with a speaker so I can also now test that before fitting it as well. Just have to find the 2 cable ends to make up a test cable for the Dolby unit to head unit.
STLV70
Year and Model: 1998 V70
Has thanked: 33 times
Been thanked: 9 times
Post by STLV70 »
It's been a year or so since I posted here. 1998 V70 base model. I replaced the left front CV axle. What a pain to remove! I tried everything from my initial searches online and in my trusty Chilton manual, but it took a third or fourth deeper dive online to discover mention of an axle popper. I ordered one out of despair, and within a few minutes after it arrived, the axle was out....along with way more transmission fluid than I was expecting :o Next up is new brakes and hoses all the way around (including e-brake refresh), rear shocks, tie rods, end links, and heater core. That should get me pretty close to "stage 0"
1998 V70 Base - "Lazarus" - 180XXX
2001 V70XC - "Gustav" - 200XXX
454cid
Post by 454cid »
Nothing to my 850, but I did go look at a P3 with the 3L turbo SI6 today. Lots of codes so I'll have to do some research. Weirdly it seemed to have multiple of the same codes. Easiest one, I assume, is a low temp code which should be a thermostat. Others were evap, cat, and one that said "manufacturer control", which I expect means it's propitiatory and my cheapy reader doesn't have the info.
I also looked at a Range Rover that I really liked, but also has a few issues, one of which is the BMW 4.4l engine that is known to have timing chain issues. It sounded like it had a supercharger on it when first started, which was odd.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Val, Brodie and myself went to the Classics for Cancer show at Bathgate today. He met up again with Roxy and had another 15 minutes of play
Another Volvo parked next to us
Brodie wasn't walking any further until he had a rest
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
