DennisCA
Year and Model: 1996 850
Has thanked: 6 times
Been thanked: 71 times
Post by DennisCA »
Begun work on the tailgate, angle grinder and steel brush to start with. First step is to get as much rust as possible away.
I wouldn't mind a hint on how to remove the plastic trim. I got the 4 nuts remove from the inside and it's loose but there are two linkages from the locking mechanism still holding it in place, not sure how I get them off. Do I need to remove the lower latch?
Has thanked: 1613 times
Been thanked: 4078 times
I’ll try link to lower latch repair. There are linkages up to that keyhole you need to remove
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
DennisCA wrote: 16 Sep 2025, 22:41 Begun work on the tailgate, angle grinder and steel brush to start with. First step is to get as much rust as possible away.
For good painting results, do much more surface preparation than you think you need.
But you knew that already.
Chieber
Year and Model: 1998 v70
Has thanked: 69 times
Been thanked: 49 times
Post by Chieber »
Junkyard time! Fun with a buttplug 😂
1/2 a shitbox V70 1998 2.5 NA
DennisCA
Post by DennisCA »
volvolugnut wrote: 17 Sep 2025, 07:19
Yeah I got the linkages and the trim off, plan is to take it down to bare metal, phosphoric acid treatment and prime it with 2k epoxy. Going need some 24 grit discs here. 40 ain't cutting it!
edit:
Sigh!!!! Tailgate closed on me and now I can't open it. The interior release latch doesn't seem to be doing anything either.
edit 2: Open, thankfully I had all the trim off so once I crawled into the back I could remove the lever and open the latch by depressing the linkage that was loose
Chieber wrote: 18 Sep 2025, 03:19 Junkyard time! Fun with a buttplug 😂
That’s a beautiful brick floor for a junkyard!
454cid
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Moved it out of the street a day or two ago. I was planning on starting the work I've been putting off all summer.... SAS system, oil change, plugs, washing the engine, and installing undershields. New plan is to start all that tomorrow.
Today, I took a look at a 2003 XC70 that seemed to be in pretty good shape. The only things that stood out to me, as negative were some paint scratches, and a vibrating blower motor. Oh, also a "message" that I didn't understand.... could be about the rear fog that didn't seem to want to turn off. Minor stuff, so I will be watching it, on auction day. I'll probably be visiting the P2 forum later tonight.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Got Evita inspected, garage called me to tell me the fuel filter job was a rust rabbit hole. , so I skipped that. No emissions on her 27 year old exempt body! Put the Curt hitch on the 2013 xc90, midway through job got bad vertigo from the rolling around. Under. Had to stop , hope I can get her done in morning
DennisCA
Post by DennisCA »
I stripped and primed the tailgate. Ground off most of the paint using a 24 grit sanding disc.
I had the whole tailgate brushed with phosphoric acid jelly then I wrapped it in plastic wrap for a couple of hours, before a wash and final sanding and priming. Rolled it on:
I'll probably need to do some fiberglass filler work before I can put down spray filler over the rest. Covering the car to protect it from over spray.
I also removed the rear bumper again to look at my homemade bumper brackets. The paint had not stuck very well to them, makes sense since I did not rough up the surface. I'm going over them with the 24 grit and using up my remaining epoxy before it sets in the pot.
Good enough, I'll hose it down with some thick rust protection once it's cured and we'll have another look next year.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Resprayed one of the Cetus wheels with Duplicolor wheel paint (HWP101 Silver).
After first light coat
After fourth coat
After fourth coat
