Has thanked: 1611 times
Been thanked: 4075 times
Is that the delta link bush or the pivot joint? The former is nasty of course, the other one not so bad
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Chieber wrote: 11 Jan 2026, 08:27 Bulbs time! Replaced all bulbs on the rear.
The og was osram. I replaced it with what was in store, which is Philips.
The difference in build was immediately seen when bulbs are placed next to each other.
Wow the old ones look robust enough to hold up a 5 pound weight
07 V50 T5 AWD M66 ~146k miles
Has thanked: 2210 times
Been thanked: 1852 times
The bush. The other end while not always a breeze unless it is the RH end (due to there the anti-sway bar attached on LH end).
It is the one where a lot of very, very, strong engineering words get used!! :o
I suggested, worst cat to just burn it out.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Yesterday my 3rd brake light started giving me problems again. I tried whacking it once and it worked briefly, than whacking it didn't work anymore. Today, I took it apart.... bulb looked fine of course.
I found that everything felt loose at bulb connections. I wanted to remove the bulb, but noticed when I turned the bulb everything got tighter. It worked after than, so I just reassembled it. We'll see how long this lasts.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Chieber
Year and Model: 1998 v70
Has thanked: 69 times
Been thanked: 49 times
Post by Chieber »
My front wheels looks like this.
So I just picked up some baby comets. Tires for 16” are so. much. cheaper.
1/2 a shitbox V70 1998 2.5 NA
Nice looking set of rims and tires! Yes, the rims do like to get really crusty after many years. Most of mine have ben powder coated over the years to keep them fresh and easier to clean.
crasbe
Year and Model: 02 S60, 98 V70 (EV)
Has thanked: 33 times
Been thanked: 82 times
Post by crasbe »
I tried to reassemble the front suspension of my V70 I today, but didn't get very far. The spring hits the body?!
The car is a 1998 V70 I with the B5254FS engine. The original spring code is 32 and the springs were marked green.
The new shocks are TRW JGM278T, the springs are KYB RA3789, the upper strut mounts are SKF VKDC 35634.
The lower control arms are TRW JTC916/JTC917.
I double checked all the part numbers in VIDA and they match
As you can see, they are bowed "outwards", but the spring sits all the way in the indentations. The spring should be the right way around, the smaller winding is towards the shock and the bigger winding towards the upper spring seat. That is the way the old springs were installed and IMO the only way they fit. What's odd is that the writing on the springs is upside down this way, but that's not the first time I've seen that.
The consequence is that I can't get the upper bolt of the wheel knuckle in before the spring hits the body.
I didn't want to open a thread for this singular issue, but did anyone ever experience something like that?
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables :D
crasbe
Post by crasbe »
So apparently it was actually the spring at fault here. You can see that the end that goes to the shock is just slightly different in terms of bending angle. But considering the actual contact area is very small, this is the most important area.
But as you can see, the old spring sits further to the front and is straighter.
The clearance between spring and frame is still quite small, but clearance is clearance I guess. Also the lower control arm is not bolted down yet (this has to wait until the car is back on the ground to avoid having the rubber in tension.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Clearance 1mm = 1m = 1km :D
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
wash
Also -> Amazon link
