Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
scot850 wrote: 29 Jan 2026, 06:35 I thought it looked like frogs legs.............
:lol: :lol: :lol:
1999 V70 GLT
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Chieber wrote: 28 Jan 2026, 16:46
Also cleaned the original oil trap by soaking it in industrial degreaser. It’s ready for a second round around the block.
Did you do a glove test before the soaking? If so let us know the after. Always wondered if degreasing could return the part back to service. Currently our 07 S60 2.5T is neutral in terms of the glove test. No suction nor inflating of the glove.
rolsen11
Year and Model: 2000 V70 SE
Has thanked: 19 times
Been thanked: 22 times
Post by rolsen11 »
New Nissens heater core and recirc flap actuator arm on order from FCP, along with some interior clips and crush washers to get that free shipping. I'm excited to finally have some good heat, a couple days ago I had to drive to work in -20F temperatures, my fingers felt like popsicles the entire drive. Never again... I hope
2000 V70 SE - Bought sight unseen in Cleveland, currently my only car. Looks identical to my profile picture
Chieber
Year and Model: 1998 v70
Has thanked: 45 times
Been thanked: 30 times
Post by Chieber »
MoVolvos wrote: 29 Jan 2026, 23:27
This is the original one on the car that I took off when I did the pcv job a couple months back.
I replaced it with an aftermarket one and kept the old apart.
But it seems there’s not much to the oil trap. This picture from cn90 shows the inside of it.
BTW. Anyone knows what this plastic bolt does? It’s on the accelerator pedal and doesn’t look like it’s connected to anything.
1/2 a shitbox V70 1998 2.5 NA
Chieber
Post by Chieber »
I used a heat gun to bend the frog legs apart. Now it does look like proper antlers.
Has thanked: 1505 times
Been thanked: 3818 times
Got the s70 out and solved the no heat problem by adding coolant. 3 liters down.
Has thanked: 1848 times
Been thanked: 1710 times
Now that looks like a moose! Well done and the moose will thank you!!
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
abscate wrote: 01 Feb 2026, 18:54 Got the s70 out and solved the no heat problem by adding coolant. 3 liters down.
That's a lot! Any idea where it's going?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
454cid wrote: 02 Feb 2026, 08:22
Not yet. There is a seep at the right side radiator Metal-to-plastic tank junction. I hope that is it.
If not, both seats will have to come out to drain coolant out of the body pan...
Sveedy
Post by Sveedy »
Found a couple of good parts out in the junkyard.
'99 -'00 turbo passenger side axle, and a V.V.T hub still on the cam.
I'll toss the cam.
1999 V70 GLT
