MY bad. I should have provided more information. JBlackburn you made an excellent point. Thank you.jblackburn wrote:DON'T do that if the PCV system isn't venting like it should. If you have smoke from the oil dipstick, DO NOT replace the oil seal cap. You'll start venting out/blowing out your engine seals instead.Before tearing your pvc system apart because you have oil under the spark plug cover, replace the oil filler cap.
In my case, I had no oil coming out of the dipstick tube, no pressure build up at the dipstick tube, but I went ahead and replaced the pvc system because it had never been done at about 210k miles and the car has been in the family since new. After the pvc system change, when I noticed that oil was still building up under the spark plug cover thats when I replaced the oil filler cap.
