Did an oil change today, treated her to 6 quarts of synthetic 5w30. I usually run 5 or 10w40 in the summer.
Replaced a seat heat switch that shot across the compartment when I was removing the tray. Note that the backlight on these switches is the same as those used on the radio IIRC.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 126 times
Re: What did you do to your Volvo today? (now Sticky!!)
- raivis_rsn
- Year and Model: V70 1999 TDI
- Been thanked: 7 times
They are the same everywhere in the dash except ECC, there you need same type but bigger bulbs.wizechatmgr wrote: ↑07 Dec 2018, 19:37 Replaced a seat heat switch that shot across the compartment when I was removing the tray. Note that the backlight on these switches is the same as those used on the radio IIRC.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I've never felt so bad for a non-sentient object.bmdubya1198 wrote: ↑07 Dec 2018, 13:37 I also came across this gem at the junkyard today. Spot the problems...
Knows enough to be dangerous
brunocerous
- Year and Model: 1998 V70
- Has thanked: 284 times
- Been thanked: 36 times
I decided to jump the new starter in the '99 V70 XC. The battery was weak (12.3V) but seemed to be enough to engage the starter. It's still not starting. (Video below.) After cranking it again for about 8 seconds, it made a nasty gear-grinding sound.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- Has thanked: 304 times
- Been thanked: 517 times
Hmm... have you checked for fuel and spark?brunocerous wrote: ↑08 Dec 2018, 15:15 I decided to jump the new starter in the '99 V70 XC. The battery was weak (12.3V) but seemed to be enough to engage the starter. It's still not starting. (Video below.) After cranking it again for about 8 seconds, it made a nasty gear-grinding sound.
Yeah, it was pretty bad.
- Has thanked: 1505 times
- Been thanked: 3817 times
Bruno..that could just be the solenoid chattering due to low voltage
brunocerous
I charged my battery overnight and jumped the new starter ('99 V70 XC) but now get a spinning sound.
Did I fry my starter somehow?
Fuel pressure looks good.
- June
- Has thanked: 523 times
- Been thanked: 261 times
Have you tried to rotate the engine by hand. Could be a bad spot on the flywheel? Or bad bendix on the starter? From the sound I am assuming the engine is not rotating. Ford cars were famous for this 40 years ago. Sometimes by engaging (bumping) the starter for a split second several times quickly would get the starter to engage the flywheel again at least on the Fords with a bad starter bendix. If it is a flywheel tooth than you will have to spin the engine slightly by hand. It is worth a try, June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
That doesn't sound good. I assume it wasn't a low voltage issue if you just charged the battery. It's possible the starter is already dead (or it was just poorly manufactured) especially if you're been cranking it for long periods without giving it time to cool off.brunocerous wrote: ↑09 Dec 2018, 07:32 I charged my battery overnight and jumped the new starter ('99 V70 XC) but now get a spinning sound.
So you've got fuel, that's good. You're getting spark, right?
- Has thanked: 292 times
- Been thanked: 765 times
Did a remote fuel pump swap on the S70 I gave to my mother in law. On the phone on Tuesday with my brother in law who is an HVAC tech, quickly diagnosed the no-start as dead fuel pump, I ordered them a Walbro and Volvo gasket from AutuHausAZ (MIL is near Phoenix), parts arrived Thursday, car up and running Thursday afternoon.
She had telephone quotes ranging $700 - $1500 for the job. We got done for $150, including a new fuel pump relay for insurance. The factory relay was still in there.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
