wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Did an oil change today, treated her to 6 quarts of synthetic 5w30. I usually run 5 or 10w40 in the summer.
Replaced a seat heat switch that shot across the compartment when I was removing the tray. Note that the backlight on these switches is the same as those used on the radio IIRC.
2023 Lexus RZ450e -66k
raivis_rsn
Year and Model: V70 1999 TDI
Been thanked: 7 times
Post by raivis_rsn »
wizechatmgr wrote: 07 Dec 2018, 19:37 Replaced a seat heat switch that shot across the compartment when I was removing the tray. Note that the backlight on these switches is the same as those used on the radio IIRC.
They are the same everywhere in the dash except ECC, there you need same type but bigger bulbs.
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
bmdubya1198 wrote: 07 Dec 2018, 13:37 I also came across this gem at the junkyard today. Spot the problems...
I've never felt so bad for a non-sentient object.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
I decided to jump the new starter in the '99 V70 XC. The battery was weak (12.3V) but seemed to be enough to engage the starter. It's still not starting. (Video below.) After cranking it again for about 8 seconds, it made a nasty gear-grinding sound.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
brunocerous wrote: 08 Dec 2018, 15:15 I decided to jump the new starter in the '99 V70 XC. The battery was weak (12.3V) but seemed to be enough to engage the starter. It's still not starting. (Video below.) After cranking it again for about 8 seconds, it made a nasty gear-grinding sound.
Hmm... have you checked for fuel and spark?
WhatAmIDoing wrote: 08 Dec 2018, 14:52 I've never felt so bad for a non-sentient object.
Yeah, it was pretty bad.
Been thanked: 4071 times
Bruno..that could just be the solenoid chattering due to low voltage
brunocerous
I charged my battery overnight and jumped the new starter ('99 V70 XC) but now get a spinning sound.
Did I fry my starter somehow?
bmdubya1198 wrote: 08 Dec 2018, 16:30
Fuel pressure looks good.
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
Have you tried to rotate the engine by hand. Could be a bad spot on the flywheel? Or bad bendix on the starter? From the sound I am assuming the engine is not rotating. Ford cars were famous for this 40 years ago. Sometimes by engaging (bumping) the starter for a split second several times quickly would get the starter to engage the flywheel again at least on the Fords with a bad starter bendix. If it is a flywheel tooth than you will have to spin the engine slightly by hand. It is worth a try, June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
bmdubya1198
brunocerous wrote: 09 Dec 2018, 07:32 I charged my battery overnight and jumped the new starter ('99 V70 XC) but now get a spinning sound.
That doesn't sound good. I assume it wasn't a low voltage issue if you just charged the battery. It's possible the starter is already dead (or it was just poorly manufactured) especially if you're been cranking it for long periods without giving it time to cool off.
So you've got fuel, that's good. You're getting spark, right?
Has thanked: 311 times
Been thanked: 817 times
Did a remote fuel pump swap on the S70 I gave to my mother in law. On the phone on Tuesday with my brother in law who is an HVAC tech, quickly diagnosed the no-start as dead fuel pump, I ordered them a Walbro and Volvo gasket from AutuHausAZ (MIL is near Phoenix), parts arrived Thursday, car up and running Thursday afternoon.
She had telephone quotes ranging $700 - $1500 for the job. We got done for $150, including a new fuel pump relay for insurance. The factory relay was still in there.
