What do I do to test it, or fix it, or do I just need to replace it?cn90 wrote: 01 Sep 2020, 19:10 Yeah,
This is my suspicion all along. The infamous "Volvo Magneti Marelli".
Do a google search: "Volvo Magneti Marelli"...
FDPP #2
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
- Been thanked: 504 times
I think you need to do some reading first.
Very complex topic.
"precopster" in this forum seems to be the guru...
Search Google: "Matthews Volvo ETM Magneti Marelli"...
Very complex topic.
- Has thanked: 2857 times
- Been thanked: 1332 times
viewforum.php?f=12 Enough info there to choke a horse.
Does anyone here know much about the "Contactless Rebuild Kit" by Module Master on ebay?
https://www.ebay.com/itm/FOR-SALE-99-00 ... 2405655073
I don't, but some here have tried them: search.php?keywords=%22Module+Master%22 ... mit=Search
- gnalan
I'm more confused now than I already was. Do I need to replace the ETM, or do I have more problems that need to be checked, fixed, and/or replaced, first, or in addition to, a new ETM?
- gnalan
Looking at the date code, the ETM was made the 1st week of 2001, and from my vin was just under the 35,000th car built in 2001. 182k miles out of the factory ETM isn't too bad. Maybe a record?
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
SuperHerman and darrylrobert (and many others) have done the contactless ETM rebuild. There is a contactless rebuild procedure for the throttle pedal on the early P2’s as well.
viewforum.php?f=12&sid=ea9c121068a4e88c27ae65b8de1d62c0
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- gnalan
This would be one less thing to worry about going bad, unless that's what is bad and making it look like it's the ETM.- Pete - wrote: 01 Sep 2020, 21:46 There is a contactless rebuild procedure for the throttle pedal on the early P2’s as well.
Does anyone know where to find the contactless rebuild kit for the pedal? I can't seem to find any doing a Google search.
- Has thanked: 316 times
- Been thanked: 531 times
Wow, that's an old one! 2001 date code. I'm betting it's shot. You're fortunate to have gotten so much time out of it!
I also don't think I properly calibrated it. There is a really great thread over on Volvospeed showing the whole process. From what I remember, it works really well and it lasts when rebuilt properly. It's essentially the same process Xemodex uses, except they also refresh the bearings and other parts.
If you're good with precision soldering, it'll probably last. I tried one of these kits and it lasted about a week. Took it apart again, re-soldered it, lasted a little longer. Ended up eventually finding a Volvo contactless ETM at the junkyard. That's the best option... cheap and pretty much fail-proof.cn90 wrote: 01 Sep 2020, 20:24 Does anyone here know much about the "Contactless Rebuild Kit" by Module Master on ebay?
- 2703 Views
Last post by YYC850
- 29 Replies
- 4102 Views
Last post by foggydogg
- 1321 Views
Last post by volvolugnut
- 635 Views
Last post by rcherry506
