Need help with setting sequence of repairs
Ben850
Been thanked: 7 times
Re: Need help with setting sequence of repairs
Post by Ben850 »
This may be a silly question, but if you are doing the inner and outer tie rods on that side, Why not just cut the boot and unscrew them from the rack together? You must have been quite frustrated from the looks of that tie rod.
Ofcourse I planned on replacing the boots as well.
That would also give you a very close measurement for the new ones. I think that is what I did with one side at least.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
cmblackburn
Year and Model: 1998 S70 T5M
Has thanked: 1 time
Post by cmblackburn »
That's what I'm thinking about doing as well. I'm replacing both at once. Seems like it would be less trouble. :wink:
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
schmidm90
Year and Model: 2000 V70 XC AWD
Post by schmidm90 »
I ordered a new inner/outer tie rod for the driver side and plan on removing both at the same time right at the rack. This will allow me to get an "accurate" measurement for the new ones. Thanks to FCP for the cybersale!
Will keep everyone posted on how it works out!
2000 V70XC - 199k
1981 VW Vanagon Diesel Westy - 220k
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
Euphoria!
I have completed ALL items set in my OP. I mean 5 days of work with daily chores of living.
It takes the road like a pro.
Year and Model: 2004 V70 2.5T
Been thanked: 472 times
Post by cn90 »
Wow, great job.
Nothing beats a strong human will!
Tonyx
Year and Model: 2001 XC70
Has thanked: 3 times
Been thanked: 8 times
Post by Tonyx »
xHeart wrote:Subframe components are key to restoring stability, but often ignored. Suspension steels the show.
Can you elaborate on this? And any lessons learned from having done your subframe bushing?
2003 XC70 230K and counting..,
xHeart
Post by xHeart »
Thank you for brining up the subframe bushing back to surface.
The issue is not resolved cause Volvo service says there is no history of replcing it in their shop, ever, on these cars. However, one senior tech did see the collapsed rear-driver's, checked the torque and said it is not going any where.
I asked, if the shop has ever serviced a Volvo this old... Silence.
My car's front ride height is 15" at PS and 14.5" at DS. This difference equals the gap no longer held between the frame and the subframe. I am not sure how geometry works between the two frames.
Picking on it a bit more, I have all 4 new tires now, but on the older ones, the two driver's side inner treads were rounded and flat while the outter was at 8/32. these were rotated at the 3k intervals during the life of it.
I have greatly improved handling since replacing all the front suspension parts, and the rear shocks.
