Has thanked: 1613 times
Been thanked: 4077 times
Hold off on polishing that R.
A very strong gust of Volvos passing you will clean it off nicely.
(Back to you)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Lots of Volvos passing me now... I can't find a friggin' axle!
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
Last night. I've never pulled an engine, so this is a milestone for me.
What's the occasion? Swap or did you want to clean the back?
Congratulations!
j-dawg
Post by j-dawg »
thanks! it kept blowing out seals and dipsticks, and it burned a ton of oil, even after a PCV overhaul. I figure the rings are toast. not sure how that happened as I don't recall letting it run low on oil; plausibly the several months to a year of dirt road driving around work with a giant hole in the brake booster hose drew in a lot of grit, scoring the cylinder walls.
I got an 02 motor, with the 147mm con rods, and I have a ton of other repairs and maintenance to do while I'm in there (single mass flywheel and R clutch, IPD sway bars, steering rack adjustment, Quaife LSD, CV boots, probably more). it's gonna be a pretty long job, but I think it'll remedy a lot of the car's issues and address some of its performance shortcomings. once it's back on the road I'll get good sticky tires and maybe swap in a bigger turbo.
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
Congrats!
How long did it take?
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
He's halfway through.
Jdawg....if that engine is headed for scrap , could you give that brass stopcock othe back cooling pipe a twist to see of ot comes out easily? I've never had the guts to take mine out for coolant flushing and ever read anyone using it. I'm curious.
Still got that third seat BRUNO...heated too.
Hope to sneak into garage over lunch and see if Evita S70 engine has freed up.
bmdubya1198
j-dawg wrote: 09 Jan 2019, 00:48 thanks! it kept blowing out seals and dipsticks, and it burned a ton of oil, even after a PCV overhaul. I figure the rings are toast. not sure how that happened as I don't recall letting it run low on oil; plausibly the several months to a year of dirt road driving around work with a giant hole in the brake booster hose drew in a lot of grit, scoring the cylinder walls.
Nice! I'd love to pull the engine out of my R just to clean things up and replace one or two things, but it seems like overkill. Especially since I already swapped out the trans from the bottom.
abscate wrote: 09 Jan 2019, 05:38 He's halfway through.
I actually drained coolant from the block on my R using that valve, it came loose pretty easily. I just wanted to get as much of the old stuff out as I could, I hate flushing coolant. Plus I think there may have been some radiator stop-leak in there, so I definitely wanted all of that junk drained out.
Then again, this is a southern car (well, it was originally sold in Colorado, but it's been in NC/SC for most of its life). Your NY rust may yield different results!
j-dawg
Post by j-dawg »
brunocerous wrote: 09 Jan 2019, 05:05 Congrats!
About three days of work up to this point. Now that all the plastic clips are broken and most of the screws are lost, it'll probably go faster next time.
I'm going to move that pipe over to the new engine as the sump cooler pipes are different on the 02 motor. But I'll crack it on the pipe that comes off the new engine. I'd love a good coolant drain - seems like there's coolant hoses everywhere on these turbo cars, and I hate discovering coolant where I didn't expect it.
Thats another 10 laps for me and June...and Im going to be driving Evita - Dont cry for me....
