Anybody want to peek at how to turn an Arduino into a J2534 interface, that is VIDA compatible?
See SardineCAN by Olaf at hackingvolvo. This could be a short cut to adding capabilities to this project. He has a J2534 Win32 DLL ... could that be ported to Linux?
Vida CEM swapping
- RickHaleParker
- Been thanked: 980 times
Active
Past
Past
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
That does not need to be ported to Linux to run VIDA. VIDA will only work on Windows. So if your primary OS is Linux, you just run VIDA in a virtual machine and pass your DiCE/Sardine/whatever USB device to that virtual machine, where it is handled by the Windows driver.
- RickHaleParker
I was thinking a native Linux J2534 might come in handy in the future.
Getting VIDA to run native under Linux would be a ton of work which nobody wants to do. The biggest obstacle would be that VIDA uses ActiveX framework. Vida would need to moved to a different framework before anybody can dream of porting it to another OS.
ActiveX framework is the reason you need Internet Explorers rendering engine to access the VIDA server. No other browser has ActiveX.
Active
Past
Past
- RickHaleParker
A J2534 DLL is the translator between J2534 and the manufacturer's low level hardware protocol. Somewhere in the source code for Olaf's Win32 DLL should be all or some of the Volvo low level protocols Olaf discovered ... unless he stuffed it in the Arduino code.
Active
Past
Past
urosm
- Year and Model: 2015 Volvo XC70 D5
- Has thanked: 10 times
Hello,
Today I tried to crack CEM PIN from 2014 Volvo XC90 (P2), but without success.
CEM P/N is: 31394158
I tried 3 times, but cracker won't or can't crack it.
In attachment is a log file.
What to do?
Thanks in advance!
What to do?
Thanks in advance!
Volvo 744 TDIC SOLD, 1989. ; 1997. - 2000.
Volvo 855 GLT + LPG Estate SOLD, 1996. ; 1998. - 2020.
Volvo V70 D5 SOLD, 2004. ; 2013. - 2021.
Volvo XC70 D5 SOLD, 2007. ; 2017. - 2021.
Nissan Pathfinder DRIVING, 2007. ; 2019. -
Volvo XC70 D5 DRIVING, 2015. ; 2021. -
Volvo XC90 D5 DRIVING, 2008. ; 2022. -
vtl
J2534 is a pass-through protocol, i.e. allows sending a raw CAN frames, without any translation.RickHaleParker wrote: 26 Dec 2021, 00:14 A J2534 DLL is the translator between J2534 and the manufacturer's low level hardware protocol. Somewhere in the source code for Olaf's Win32 DLL should be all or some of the Volvo low level protocols Olaf discovered ... unless he stuffed it in the Arduino code.
vtl
urosm wrote: 26 Dec 2021, 14:08 Hello,
What to do?
Thanks in advance!
log.txt
Code: Select all
Calculating bytes 0-2
1000 pins in 573 ms, 1745 pins/s, average response: 21 us, histogram 10 to 31 us
us: 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
[ 00 -- -- -- -- -- ]: 0 0 0 0 0 0 0 0 3000 0 0 0 0 0 0 0 0 0 3913 418835890 : latency 63000; std 621.92
- RickHaleParker
Yea ... something like 80 - 90% of the latencies are 63000, the longest value.
Active
Past
Past
- RickHaleParker
You have IO Terminal or access to IO Terminal. Can you extract the .bin and/or PIN?
Active
Past
Past
- RickHaleParker
vtl wrote: 26 Dec 2021, 14:44 J2534 is a pass-through protocol, i.e. allows sending a raw CAN frames, without any translation.
I am interpreting that as SardineCAN includes the translations. How else could Olaf be sure it would work with "various diagnostic programs". The whole idea of J2534 is that the client side developer does not need to know the low level protocols. The dll with translate the request and pass it through.Olaf wrote: This is Sardine CAN, an open source J2534 device, which makes it possible to connect various diagnostic programs (eg. VIDA from Volvo) to your car.
Active
Past
Past
- 9511 Views
Last post by RickHaleParker
- 9640 Views
- 27 Replies
- 29814 Views
Last post by cn90
- 11221 Views
Last post by jonesg
- 6324 Views
