My $70 eBAY DiCE unit crapped out after about 2 hours of usage. I can still see it in device manager but it will not longer communicate with Vida or with the DiCE diagnostic tool program. I tried to go with a well-rated vendor but seems that wan't good enough.
So a bump here - any current recommended source(s) for a DiCE unit?
VIDA DICE, which one to buy?
VIDA DICE: What to buy?
- Has thanked: 311 times
- Been thanked: 817 times
TacklaNHL
- Year and Model: Volvo S60R 2006
- Has thanked: 1 time
- Been thanked: 4 times
Sorry for the delay Ian.... the DICE units that we get from ebay are fine, in every way. You can use this DICE unit with VIDA 2014D (the cracked version that we all use at home), or with VIDA 2015 (the current version that dealers use, which requires a license.)
A good dice unit, shipped from the US, and quick.... is $72 on ebay.
Corrupted DVD's.... dual layer is not something i've seen. I've seen incomplete files mainly. You'll attempt to install, for weeks, and it'll constantly give you headaches. Mainly because the files are incomplete.
2006 S60R AWD M66 Passion Red -- Denver, Colorado
2016 XC60 T6
2019 XC90 T6 R-Design Polestar
Pre-Installed VIDA laptops for sale, plug-n-play, DICE, Mongoose, Boot&Go, lifetime warranty, thousands of satisfied customers!! DiagLaptops.com
2016 XC60 T6
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Is the "Licensed" unit any different than those on eBa, i.e. we use.
DiCE Admin Tool connects, and tests it OK over USB
I updated VIDA from 2014A to 2014D. 2014D open fine, but would not communicate with DiCE. Nor would VIDA read the car via DiCE over ODB2.
Am I missing a step in sequence?
TacklaNHL
Yes, they are different. The genuine ones have Bluetooth and may have a different controller board. But it still works.
I’m not sure what that issue is... probably a DICE firmware update?
2016 XC60 T6
2016 XC60 T6
Jonboy74
- Year and Model: V70 2.4T, 2002
- Has thanked: 119 times
- Been thanked: 15 times
For what it is worth, I just bought this unit and used it today to reset my SRS warning light on the DIM on my 2002 V70 2.4T, and it worked just fine.
I'm not affiliated with this seller and am not getting compensated in any way. just sharing information. I will say that I followed RickHaleParker's guidance for the VIDA install on my Win 10 Pro laptop. I did NOT use the software that was provided with the DiCE module.
https://www.ebay.com/itm/2014D-VOLVO-VI ... 2749.l2649
Hope this helps,
Jonboy
Hope this helps,
Jonboy
PainterPaul
- Year and Model: 2004 S60 R
Can a VOLVO VIDA DICE Diagnostic Tool be used to program an REM with the VIN info if I purchase a used part off of EBAY?
TacklaNHL
Yes. It can. But you’ll be using vida 2015 to program anything. Which is $75+tax just to login. Then it’s extra to download the software you want to program.
2016 XC60 T6
2016 XC60 T6
PainterPaul
Thanks
Which one should I buy?
Can you recommend a link to get all that I need. ?
2004 S60 R
2004 S60 R
TacklaNHL
I sell them for $120 shipped.
Or you can check eBay for one. You’ll pay more for a US seller usually. Or around $90-95 if you don’t mind waiting 2-3 weeks. They are all the same these days.
2016 XC60 T6
2016 XC60 T6
PainterPaul
Ok
What is the link to make the purchase?
And,
Is it fairly idiot proof to follow the instructions to program the REM?
Thanks
And,
Thanks
- 8020 Views
Last post by lrock
- 16398 Views
Last post by xiaofei204716
- 805 Views
Last post by jonesg
- 19129 Views
Last post by jonesg
- 7133 Views
Last post by Klem
