Vida CEM swapping
Sh4rp
- Year and Model: See below.
- Has thanked: 2 times
Here are the dumps for the not crackable CEM. - Sorry for double posts... MVS threw some SQL error.
EEP (L).txt- (2 KiB) Downloaded 94 times
EEP (R).txt- (4 KiB) Downloaded 86 times
Flash (L).txt- (2 MiB) Downloaded 80 times
Flash (R).txt- (2 MiB) Downloaded 84 times
2004 - V50 T5 AWD M66 - Flint Grey
1996 - 850 T-5R M56 - Dark Olive Pearl
- RickHaleParker
- Been thanked: 979 times
Cleanup on aisle CEM
Active
Past
Past
The order is 5, 2, 1, 4, 0, 3. Could you try it with shuffle order set to 2?
Not working.
Not working.
P1_Not_OK_02.txt- (143.05 KiB) Downloaded 94 times
- RickHaleParker
5, 2, 1, 4, 0, 3. is shuffle order 2.AA2020 wrote: 09 Feb 2022, 04:56 The order is 5, 2, 1, 4, 0, 3. Could you try it with shuffle order set to 2?
Not working.
unsigned char shuffle_orders[4][PIN_LEN] = { { 0, 1, 2, 3, 4, 5 }, { 3, 1, 5, 0, 2, 4 }, {5, 2, 1, 4, 0, 3}, { 2, 4, 5, 0, 3, 1} };
-------------------------------------------------------------------- Order 0 ---------- Order 1 ------------- Order 2 ---------- Order 3 -------
{ 8690720, CAN_500KBPS, 2 }
Just edit the highlighted to change the shuffle order for 8690720.
Or you can down load the latest code. Shuffle order has been set back to 0 because P1 owners where having trouble with shuffle 2.
Active
Past
Past
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
He did already:RickHaleParker wrote: 09 Feb 2022, 06:57 Just edit the highlighted to change the shuffle order for 8690720.
Code: Select all
13:11:47.497 -> Part Number: 8690720
13:11:47.497 -> Searching P/N 8690720 in 50 known CEMs
13:11:47.497 -> CAN HS baud rate: 500000
13:11:47.497 -> PIN shuffle order: 5 2 1 4 0 3
13:11:47.497 -> CAN high-speed init done.- RickHaleParker
8690720 will not crack on 0 or 2?
Active
Past
Past
- 9188 Views
Last post by RickHaleParker
- 9098 Views
- 27 Replies
- 28252 Views
Last post by cn90
- 10552 Views
Last post by jonesg
- 5706 Views
