2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
Hey all just joined the forum as I've gathered a ton of info here. Been a busy last month for me.
2002 S60 2.4T with 180k miles got new CV shafts to solve a 70mph shudder. While there did lower control arms that were shot and engine mounts. Runs like a top. Went with TRQ parts so hope they hold up. Had the car a bit over two years (since 150k) and been a good runner.
Bought a 2008 S60 2.5T last month with 138k miles. Overall very nice cosmetically, a number of TLC items done:
Oil and filter change (Castrol Ultraclean 5w30)
Trans fluid drain and fill (Val Maxlife)
Strut assemblys
Swaybar links
Lower Control Arms
Ball joints
Sunroof shade guides
A-pillars (fabric falling off, swap to plastic)
One item I forgot to check at purchase was the rubber glove test, so hitting my maintenance and repair wall I sent it to an independent shop in town to do the PCV, rad hoses, thermostat and have the throttle body cleaned. Fortunately it was pushing only a little air with cam seals in tact. Cut 1/4" out of the oil cap gasket to prevent further issues.
Ready to just drive them lol.
08 C702.5T (sold)
The non-Swedes:
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 80 times
Been thanked: 175 times
Post by - Pete - »
vtl wrote: 08 Jan 2022, 16:45 shot it with a bolt from my 370 FPS crossbow, it didn't penetrate.
I have a video of the process, but too shy to post it here (not enough beer consumed).
Interesting choice of target and interesting method of testing your radiator protectors protective abilities ;)
What intercooler is that behind the screen?
Nice fitment on the welded SS guard by the way!
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
- Pete - wrote: 09 Jan 2022, 10:02 What intercooler is that behind the screen?
That's my Hayden transmission cooler.
Yeah, stick welding stainless sheet metal was entertaining, especially with my near zero welding skills and a 25 gallons kettle of freshly brewed, 8% ABV "Six feet under" that was going to spoil quickly in summer weather and had to be consumed timely ;) Lots of weld-grind-cut-redo cycles.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Krons wrote: 09 Jan 2022, 08:59 Cut 1/4" out of the oil cap gasket to prevent further issues.
That is going to give you issues. Oil will leak out and collect on the top of the Cam cover. May even seep down into the spark plug wells.
Krons
Post by Krons »
RickHaleParker wrote: 09 Jan 2022, 15:05
Yes, was only a short-short term fix until the PCV is fixed this week. It was that or risk blowing cam seals...pick your poison. Plugs will get changed this week to clean things up.
08 C702.5T (sold)
The non-Swedes:
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
It is easier and reversible to pull the dip stick out a bit to relieve pressure.
Krons
Post by Krons »
volvolugnut wrote: 09 Jan 2022, 18:11 It is easier and reversible to pull the dip stick out a bit to relieve pressure.
I have a fresh oil cap gasket in the garage for when it gets home. The old one was crusty enough it wasn't sealing tight when I bought it. Fortunately caught this one pretty early.
Good tip on the dipstick though, any bit helps to keep the seals intact when it is building crankcase pressure.
08 C702.5T (sold)
The non-Swedes:
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
abscate wrote: 09 Jan 2022, 05:13
MoVolvos wrote: 08 Jan 2022, 16:29
abscate wrote: 06 Jan 2022, 20:08
Rolled the P2 down to her new home on Long Island.
Took Husky on ferry
Picked up Abby’s brake parts
That ferry ride looks like fun besides the view. Only time ever took a large boat ride was in 84. First time in China. Overnight and was much slower back then and super cold.
https://www.rome2rio.com/s/Yantai/Dalian
You go up top on the ferry and the view of along Island Sound is beautiful.
The trip is $12 passenger/$60 car , about 15 miles and takes 75 minutes. The alternate route is to go through NYC , 90 miles of heavy urban traffic (1-4 hours) and $30 in tolls. It’s a no brainer since I can walk from ferry to house in Port Jefferson.
Can you provide the location of the ferry and is it too hot and humid in the summer to be on deck?
Has thanked: 1502 times
Been thanked: 3817 times
It runs from Bridgeport CT to Port Jefferson NY
Top deck in summer is nice, the Sound stays about 70F max so it’s never hot.
Krons
Post by Krons »
2002 got some surgery tonight. I removed a lava lamp (former autodimmer) from the rearview mirror and transplanted the mirror guts into a manual model with good glass. Satisfyingly easy project with a good result.
VIN coding a mirror? Yea, that makes sense...
:roll:
08 C702.5T (sold)
The non-Swedes:
