What is the theory?gnalan wrote: 29 Apr 2022, 09:27 I'll work through it when I get a chance to, and if I don't see the theory in my head in his code I'll either do a rewrite on GitHub or post something here.
Vida CEM swapping
- RickHaleParker
- Been thanked: 980 times
Active
Past
Past
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
I'm not sure now. I'm not familiar with BCD, and I was thinking in my head that it was hex values that were needed.
I need to learn what BCD is and how exactly to work with it. Then do some calculations with it to see exactly how it works hands on before I can code with it. Plus I like to learn, so it'll be fun to see just what can be done with BCD.
I'm sure vtl has already optimized it, but if there's still more that can be done I'd like to add what I can to help.
- RickHaleParker
BCD Binary Coded Decimal. A nibble represents one of the 10 decimal characters.gnalan wrote: 29 Apr 2022, 13:05 I'm not sure now. I'm not familiar with BCD, and I was thinking in my head that it was hex values that were needed.
Hex is exactly the same as BCD except a nibble can represent any of the 16 Hexadecimal character.
4 bits can represent 16 charters. In BCD 6 of the possible states are not used. In Hex all 16 are used.
BCD is how you count with 10 fingers ( base 10 ). Hex is how you count with 8 fingers and 8 toes ( base 16 ).
Active
Past
Past
Power6
- Year and Model: 2019 S60
- Has thanked: 1 time
- Been thanked: 12 times
I have updated PINMagic to deal with the DiCE session log files, this should work for P3 now since DOIP is not an option with VIDA. If you have a VIDA log file with a CEM unlock in it, you can get your PIN in seconds. If anyone tries it out let me know if you have problems, I had an extremely limited set of DiCE logs from VIDA to develop and test it. You can also use LogMagic to decrypt the log as well to see the interesting log lines for yourself.
https://spaycetech.azurewebsites.net/LogMagic.html
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
All CEM pinouts can be found in VIDA. For the brick-shaped CEM you need a K-Line addition to the cracker. I think someone reported he was able to talk to CEM using non-OBD CAN pins. They are open at all times.
- charlie13
- Year and Model: 2009 XC70
- Been thanked: 18 times
Sorry. But I found nothing in vida EWD. Nobody has written anything on the forum whether it works, the K lines can be given from vidavtl wrote: 06 May 2022, 09:07 All CEM pinouts can be found in VIDA. For the brick-shaped CEM you need a K-Line addition to the cracker. I think someone reported he was able to talk to CEM using non-OBD CAN pins. They are open at all times.
- 9999 Views
Last post by RickHaleParker
- 10420 Views
- 27 Replies
- 31911 Views
Last post by cn90
- 12299 Views
Last post by jonesg
- 7205 Views
