XC60D5 2.4L Twin turbo 2012
Marzzy
- Year and Model: 2015 xc60 R design
Thank you I see that now. No problem . I appreciate . Next is finish off setting up dice. I may have to gamble with ebay. Next project is change oil. Castrol 5w30. Some weird prefilled? Under the hood. Hmm
Marzzy
Ahhh. Thank you. So listen to this. I changed the oil bc it was so black . The drain plug was stripped which is why no one changed the oil I assume. I fixed all that no leaks .got parts from for. NOW I get a much more aggressive leak when I run the engine. It stops when I shut it off. I cannot see where it's coming from. I looked thru right side wheel well and it's like halfway up dripping down onto the suspension parts. It isn't do this before the oil change so I might have fuzored a line or the filter I did wrong. I had to dump 7.5 quarts or oil. So I've run 15 quarts total to fix this leak. The oil was so bad both times. Now it has fresh full synthetic 5w 30 Castrol as reccomended.level is at the min level at the moment. ANY help with this would be appreciated. I'll try to post pics. Should I move this post? I get confused when on a roll thread.
- 1091 Views
Last post by abdomar528
- 2452 Views
Last post by nyc1836
- 1783 Views
Last post by 93Regina
- 1230 Views
Last post by mark0006
- 501 Views
Last post by JimBee
