S80 - 2009 - 2.5 T - alternator belt torn - engine fails to ignite
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
The valves were re-done and they didn’t remove the carbon from the combustion chamber?
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
Krons: they did it , of course.
This carbon been built during engine running for some time while testing it. Only , I guess for a few hours….
Mech says it was built so fast cause cyl1 has no compression so it effects the way fuel is burned
180,000 km.
Replaced the alternator pulley , belt and tensioner . Also alternator did not charge , so replace it with a used one and a new Bosch regulator .
Head came back and was ok.
Removed piston 1 - pressure ring was broken.
So that was probably the reason why it had no compression.
Is it common to happen ? I don’t think so.
Waiting for mech. Hoping for good for news
Well , story is not finished yet.
Engine was running very well for a few hours .
Then it started to rattle . No DTC’s.
What can be the problem?
Another thing unsolved is when control cable that comes from CEM is connected back to alternator it does not charge at all. When disconnected it charges. Any idea? (Alternator had been replaced and as well new regulator)
Any idea will be appreciated .
- 1511 Views
- 1500 Views
Last post by pgill
- 1350 Views
Last post by Cees Klumper
- 2198 Views
Last post by ferocity02
- 1639 Views
Last post by erikv11
