98 v70: fail to start when cold
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
scot850 wrote: 19 Oct 2023, 13:08 Coolant Temperature sensor. It is the sensor just under the thermostat in the housing (the item in your 17.43 post yesterday on this thread).
So it stands for Electronic Coolant Temperature I assume. I have the new coolant temp sensor on the way. Will report back, likely after the 23rd.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Has thanked: 2211 times
Been thanked: 1852 times
Just so you are aware, the only brand I recommend is Volvo OE for this. Any other brand is a crap shoot from bad out the box, to not working right or short life span. I wish you luck!
CIK7
Post by CIK7 »
scot850 wrote: 19 Oct 2023, 13:43 Just so you are aware, the only brand I recommend is Volvo OE for this. Any other brand is a crap shoot from bad out the box, to not working right or short life span. I wish you luck!
It seems Standard Motor Products has a good reputation. I assume its like using a Continental timing belt kit.
You may be the first to find out...........! :o :D
Good luck!
CIK7
Post by CIK7 »
scot850 wrote: 19 Oct 2023, 16:49 You may be the first to find out...........! :o :D
Good luck!
Is there something bad you have heard about Standard Motor Products? EDIT: I looked at the product page. It is made in Taiwan.
Nope, just never heard of them or their products. Or for that matter this particular part being used on a P80. I truly hope it works as we need a more affordable option to the OE part. Please let us know how it works out!
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
scot850 wrote: 19 Oct 2023, 16:59 Nope, just never heard of them or their products.
It's a 100 year old company and fairly well trusted. What they don't make themselves is often re-boxed products by other well known manufacturers. I think it was an SMP branded brake switch that I bought that was simply a reboxed ALPS switch.... the OEM for the Volvo switch.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
That is what I am hoping. Other suppliers like Dorman have also been found to do that as well. Time will tell. Hopefully it is a Vernet part reboxed!
Thanks for the info!
CIK7
Post by CIK7 »
Update: I was not able to find my old fuel pump relay. Today I got the new (Pro Parts Sweden) fuel pump relay. Of course it had to be incorrectly manufactured. The bronze pins were insanely longer and wider than factory. Would not fit in the socket. Return opened for it. Also got the coolant temp sensor delivered. Cannot (or will not, not sure) test until the proper relay gets here. That will give me some time for the cold nights to move back in. I did find a Standard Motor Products relay so I should be back on this thread in about a week to report back. Until then, at ease soldiers! LOL
CIK7
Post by CIK7 »
Okay I have a small update. Yesterday I got the new fuel pump relay installed. Started and ran fine. Tonight I went under the hood with the new coolant temp sensor. I was trying to remove the sensor side of the +&- wires. Turns out its the car side of the harness that the wires separated from. Not only that, but I got a true sense of deja vu (dealing with that issue before) which means my statement of the previous owner doing this stupid 'fix' is actually true. I was the previous owner (2021-2/2022) to buy the brand new coolant temp sensor (the last sensor was faulty) and then cut off the sensor side of the plastic harness for the loose harness 'fix'.
The important update is coming Sunday night or Monday night. Thats when I can test the new fuel pump relay after it gets really cold.
