Infamous ignition tumbler problem, now "Start Prevented Try Again" Topic is solved
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
vtl wrote: 20 Jan 2026, 06:56
Krons wrote: 19 Jan 2026, 19:20 A spare key is most painful…covered here on the forum ad nauseam…$440 for a fob or $113 for a valet key PLUS $224 to program either one. With an AirTag on the only functional key I may roll the dice. Just can’t swallow $337 for a spare key on a $1500 vehicle.
Break the ignition lock, so it accepts even a screwdriver. Glue your the only remaining key to immobilizer antenna. This is what I did years ago.
VTL I’ve been thinking about your reply on the ’What did you do’ P2 thread. I wonder if a good solution is to glue the good key near the immobilizer and simply buy two valet keys and skip the $200+ each of programming. Could even maybe find a local to cut the key and keep the tumblers in place and save that effort of disassembly.
08 C702.5T (sold)
The non-Swedes:
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Krons wrote: 24 Jan 2026, 05:09 VTL I’ve been thinking about your reply on the ’What did you do’ P2 thread. I wonder if a good solution is to glue the good key near the immobilizer and simply buy two valet keys and skip the $200+ each of programming. Could even maybe find a local to cut the key and keep the tumblers in place and save that effort of disassembly.
I drive like that in fact. The real immo antenna with the only key glued to it is hidden behind the dash, I even put a donor antenna on the lock, unconnected, just for the looks. The lock has been replaced with the one, which has two switchblade keys and a valet.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Just curious for those with Antenna Ring failure...
- At how many miles did yours fail?
- What were the symptoms?
vtl
Post by vtl »
cn90 wrote: 26 Jan 2026, 08:49 Just curious for those with Antenna Ring failure...
They suffer tin pest. Perhaps they almost never fail in Florida and alike states.
Two 05 have never had any antenna failures. 02 had it. I reflowed it with lead solder and that fixed it.
Krons
Post by Krons »
vtl wrote: 24 Jan 2026, 06:54
I put this plan in motion today. Had a mobile locksmith here to make a key for a recently acquired 2017 Ford Focus (likely to replace the 05 XC90…).
He’s a 20 year veteran and knows the pains of Volvo keys. He didn’t carry blanks but said to order them up and they’d cut them for me. $16 for a pair of keys on eBay and see an antenna on there for $50. Hope to be all in with two keys for $100.
08 C702.5T (sold)
The non-Swedes:
