Top of the engine is dry and when I had the stuff out for the PCV any crud up in the top half has been dry for a long time. The wet is only down low.scot850 wrote: 21 Jul 2024, 16:31 If you are getting just a lite drip from that area, it could either be RMS or rear cam seals leaking down.
Just to check, you are not getting any oil leaks at the top of the engine at the spark plug area? Sometimes when the oil filler cap gasket leaks into this area, it eventually drains to the back where there is a drain that leaks out down the back.
If it is possibly the first 2, then I would throw in a bottle of AP-205 or Blue Devil seal conditioner and take the car for a good run. In our case it was Reno to north of Sacaramento. Most of this was done at highway speeds.
Bottom line, a good steady long run. Mileage I would suggest trying 50-100 miles and see how it goes.
Don't throw the seal conditioner in until you are ready to set off.
Good Luck!
How about 1134 miles on the seal conditioner?
From Albuquerque, NM 87108 to Berkeley, California via I-40 W and US-95 N.
18 hr 19 min (1,134 mi)
https://maps.app.goo.gl/JAbBsZzWfQhbFXCi6?g_st=ac
