04 volvo xc70 car dies Topic is solved
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
There is a code within the VIN for the plastic fuel tank I believe. 64 comes to mind.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- famfeld
- Year and Model: 04 xc70
- Has thanked: 9 times
- Been thanked: 6 times
Update:
It turns out the tow truck damaged the fuel line from the filter towards the engine and it's leaking fuel. I am trying to use a universal kit to fix the broken line, but its not working well. The OEM fuel hose may be nylon with rubber over top. I am looking into replacing the entire line and now am wondering how to access the line that goes from the filter up into the car towards the engine. Do I have to take the carpet out (the seats too maybe) to access some kind of access panel?
Famfeld
Famfeld
- Been thanked: 504 times
Go to a junk yard to:
1. Get a good fuel line
2. To get to know the anatomy. Fuel line runs below car chassis, so no need to remove carpet. All you need is car on wood ramps or jack stands and you will see.
PS: cutting and splicing nylon fuel line is an art.
- br0dy519
Someone donate to that guy so he can buy a new shirt.. lol. nice video though. flaring tool and caulking gun unintended use.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
Yes on the seats, but before removing rear seats disconnect the battery or it will set an SRS fault.famfeld wrote: 04 Jan 2025, 13:30 Update:
Famfeld
Pump access hatch is on the driver side under the seat.
It also requires removing some of the side plastic panel beneath rear side window so torx drivers are needed.
You're in MA, Hollands pick n' pull is in Billerica, easy to get to from I 93. they have plenty of volvos , prices are very cheap.
https://www.google.com/search?q=Auto+Sa ... 8885534345
- 6300 Views
Last post by waffleshill
- 1039 Views
Last post by precopster
- 1256 Views
Last post by pkzip5
- 1696 Views
- 2354 Views
Last post by erikv11
