Another Car, Another Climate Issue. AC This Time. Topic is solved
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
That’s static pressure with the compressor not engaged, simply to verify my sensor is working properly. 400 kPa equates to ~58psi, which is what my gauge was showing, so it seems to be working. I can’t get the compressor to engage at all
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
- Been thanked: 4063 times
But it still engages briefly when you first command it, then drops out?
- V50M66
No, that was only the first time, when first filling the system. It refuses to engage at all now.abscate wrote: 11 Jun 2025, 02:49 But it still engages briefly when you first command it, then drops out?
If you put 12v right onto the clutch wire does it pull in?
- V50M66
Yeah. Also engages if I jump the relay pins in the fuse box. And engages during the relay test with the app posted above. It just doesn't want to work when it should under normal operation - it's not activating the relay
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
If I had to guess it's going to be a sensor issue where it thinks the pressure is too high or low in the system somewhere then. Have you tried a different CCM unit for giggles?V50M66 wrote: 11 Jun 2025, 18:40Yeah. Also engages if I jump the relay pins in the fuse box. And engages during the relay test with the app posted above. It just doesn't want to work when it should under normal operation - it's not activating the relay
Scratch that, you said MCC. Darn it. Still say I'd check the pressures reporting. That sounds a bit low at rest to me, but I haven't checked mine recently.
- V50M66
Yep, tried a new MCC module with no changes unfortunately.wizechatmgr wrote: 11 Jun 2025, 18:55If I had to guess it's going to be a sensor issue where it thinks the pressure is too high or low in the system somewhere then. Have you tried a different CCM unit for giggles?V50M66 wrote: 11 Jun 2025, 18:40Yeah. Also engages if I jump the relay pins in the fuse box. And engages during the relay test with the app posted above. It just doesn't want to work when it should under normal operation - it's not activating the relay
There's only 2 sensors in this system:
The high-pressure cutoff switch is a binary pressure switch that either allows or disallows current flow based on pressure. I've tried bypassing it (jumpering the pins) and replacing it, and all electrical measurements at both the sensor and the wiring are what they should be per VIDA, so that's not the problem.
The only other sensor is the low pressure sensor, which senses actual system pressure and reports it to the ECU. This one is reading within 10% of the crappy analog gauge attached to my AC charge hose, so I don't think this is the issue either, but I'm not sure what else could be the problem here.
So everything works up to the 4/46 ( that’s the ECU isn’t it) which isn’t commanding compressor on.
Fire up VOL FCR and check for MCC codes , there’s probably something stuck in the baffles
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
- Been thanked: 130 times
The Volvo own literature talks of 70 series code reading through its led on REC button and not anything of reader device for MCC.
Press REC button within 2 seconds after turning Ignition on > release and press twice the button > led will start flashing if any codes.
Removing codes is similar but pressing four times.
Other way around I think.V50M66 wrote: 11 Jun 2025, 20:19Yep, tried a new MCC module with no changes unfortunately.wizechatmgr wrote: 11 Jun 2025, 18:55If I had to guess it's going to be a sensor issue where it thinks the pressure is too high or low in the system somewhere then. Have you tried a different CCM unit for giggles?V50M66 wrote: 11 Jun 2025, 18:40
The low pressure switch is a binary 1/0
The high pressure switch or pressostat supplies a voltage proportional to high side pressure
- 25 Replies
- 7033 Views
Last post by Blacklab467
- 2042 Views
Last post by foggydogg
- 1122 Views
- 1480 Views
Last post by rguzz
- 3473 Views
Last post by caliwagon
